Ash Wragg Posted March 23, 2010 Report Share Posted March 23, 2010 I'v seen the monty hose splitters and heard good and bad things about them. I'm just wondering if they are worth it and do they make that much of a different Quote Link to comment Share on other sites More sharing options...
matthew_coggan Posted March 23, 2010 Report Share Posted March 23, 2010 I would say if you crack your cross over pipe quite alot then its worth getting one, but if this isnt a problem then i wouldnt bother, as i coulnt tell the difference. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 23, 2010 Report Share Posted March 23, 2010 Supposedly they're a right b*****d to fit too.....no noticeable improvement in performance to warrant their fitting. A braided hose would be far more effective to stop crossovers dying Quote Link to comment Share on other sites More sharing options...
josh barker Posted March 23, 2010 Report Share Posted March 23, 2010 run one of these with a water bleed and your brake will feel excellent! more direct feel, no delays but make sure you have a good bleed. Quote Link to comment Share on other sites More sharing options...
Borat Posted March 23, 2010 Report Share Posted March 23, 2010 They honestly make no difference in performance whatsoever. Stick with a crossover, easyer to bleed, less hassle to fit etc etc. Quote Link to comment Share on other sites More sharing options...
matthew_coggan Posted March 23, 2010 Report Share Posted March 23, 2010 run one of these with a water bleed and your brake will feel excellent! more direct feel, no delays but make sure you have a good bleed. There isn't a delay if you set it up right. Quote Link to comment Share on other sites More sharing options...
KurtiisBrookhouse Posted March 23, 2010 Report Share Posted March 23, 2010 I was just wondering what do they actually do? Kurtis Quote Link to comment Share on other sites More sharing options...
Ash Wragg Posted March 23, 2010 Author Report Share Posted March 23, 2010 run one of these with a water bleed and your brake will feel excellent! more direct feel, no delays but make sure you have a good bleed. i was thinking of trying a water bleed just with my normal cross over pipe, is it any goood with water ? I was just wondering what do they actually do? Kurtis Their meant to be a replacement for the crossover pipe because they break easily. Also they are meant to send equal amount of fluid to each cylinder for a even bite. I have heard more bad things about them so i dont think im going to bother hope that helps mate Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 23, 2010 Report Share Posted March 23, 2010 i was thinking of trying a water bleed just with my normal cross over pipe, is it any goood with water ? Their meant to be a replacement for the crossover pipe because they break easily. Also they are meant to send equal amount of fluid to each cylinder for a even bite. I have heard more bad things about them so i dont think im going to bother hope that helps mate Great...do it Quote Link to comment Share on other sites More sharing options...
