crispyboy Posted March 22, 2010 Report Share Posted March 22, 2010 Hello I am looking at carbon effect bar tapes at the moment as i need some new grips. Does anyone run it on here ? Is it any good for trials ? Thanks alot Quote Link to comment Share on other sites More sharing options...
Andrew C Posted March 22, 2010 Report Share Posted March 22, 2010 Link? Quote Link to comment Share on other sites More sharing options...
philth Posted March 22, 2010 Report Share Posted March 22, 2010 Don't do it...tapes just move, tear and come undone. I did a whole nation comp well section 3-20 with no grips because the tape failed so badly. The carbon effect is not the best feeling, its not absorbent and gets slick with its coating. Quote Link to comment Share on other sites More sharing options...
totaltrials Posted March 23, 2010 Report Share Posted March 23, 2010 Don't do it...tapes just move, tear and come undone. I did a whole nation comp well section 3-20 with no grips because the tape failed so badly. The carbon effect is not the best feeling, its not absorbent and gets slick with its coating. The sticky backing on bar tape is pathetic, but if you do it tight enough, tape the end down and push the other end into the bars and fit the bar end it shouldn't move. Did you put the tape on going clockwise or anti clockwise? You will be pulling the tape towards you more on a trials bike so it should tighten as you pull. Anyway, all that's pointless because you can just use some double sided tape and it'll never move. Some kind of micro fibre tape will be best for trials for better comfort and grip. Fizik is good. Or if you have a bit more money get the Lizard skins DSP tape as it's very comfortable. With the carbon effect, as said above, it doesn't feel as nice as a normal foam or gel tape. Quote Link to comment Share on other sites More sharing options...
indianatrials Posted March 23, 2010 Report Share Posted March 23, 2010 Bar tape is the best grip you can get, super cheap, easy to put on/take off and you can adjust thickness by how close your wrap it. Im not sure on the carbon shizzle though. Quote Link to comment Share on other sites More sharing options...
