Mockett Posted March 21, 2010 Report Share Posted March 21, 2010 Im still verry new to trials, so constructive criticism will come i handy Quote Link to comment Share on other sites More sharing options...
multi tasking male Posted March 21, 2010 Report Share Posted March 21, 2010 looking good. How long have you been riding ? Quote Link to comment Share on other sites More sharing options...
Mockett Posted March 21, 2010 Author Report Share Posted March 21, 2010 properly for around 3 months Quote Link to comment Share on other sites More sharing options...
konstant Posted March 22, 2010 Report Share Posted March 22, 2010 Is that the edge of a cliff you're riding on? Other than that it looks good One tip... try hopping off things in a really slow and controlled way. Learning to get right to edge of the obstacle and slowly dropping off will help give you the back wheel control you need for other moves. Quote Link to comment Share on other sites More sharing options...
Mockett Posted March 22, 2010 Author Report Share Posted March 22, 2010 Other than that it looks good One tip... try hopping off things in a really slow and controlled way. Learning to get right to edge of the obstacle and slowly dropping off will help give you the back wheel control you need for other moves. Taken note thank you Quote Link to comment Share on other sites More sharing options...
mister limelight Posted March 22, 2010 Report Share Posted March 22, 2010 - pump up your rear tire. - don´t let the cam shake so much. - bring out more than one clip. good riding Quote Link to comment Share on other sites More sharing options...
multi tasking male Posted March 22, 2010 Report Share Posted March 22, 2010 looking good for 3 months of riding. Quote Link to comment Share on other sites More sharing options...
matthew_coggan Posted March 22, 2010 Report Share Posted March 22, 2010 When i saw it i thought it was going to be a funny clip with you or your bike ending up in the drink. But good riding skills there especily if you have only been riding as long as you said. Quote Link to comment Share on other sites More sharing options...
Bronz Posted March 26, 2010 Report Share Posted March 26, 2010 Try keeping a finger on each brake lever at all times. You use two on the back lever and I'm sure you switch from none to one on the front when you land. Causing yourself work there… Quote Link to comment Share on other sites More sharing options...
Theo Posted March 26, 2010 Report Share Posted March 26, 2010 christ, dont fall backwards! Quote Link to comment Share on other sites More sharing options...
Mockett Posted April 1, 2010 Author Report Share Posted April 1, 2010 Try keeping a finger on each brake lever at all times. You use two on the back lever and I'm sure you switch from none to one on the front when you land. Causing yourself work there… Just tryed that (thank god the sun is out), i cant seem to do it. i loose all control on the back wheel, think i might stick t what im doing because its working for me Quote Link to comment Share on other sites More sharing options...
