Help Please
shetlandtrialsrider
Hi I have recently gotten a new chain for my Onza T-rex , I have fitted it to the bike but it keeps jumping of the front sprocket.
The two sprockets look to be inline, but the wheels of the tensioner look a little bit off compared to the two sprockets could this be the problem or is there anything else
should check for?
Cheers, James (Y)
Edited by shetlandtrialsrider
make sure you have enough chain wrap, i would consider if you have had the sprokets on the bike long to replace them as they wear and stretch a bit which causes the chain to engage in the sprocket in-correctly.
Edited by josh barker
