Hope Bleed Nipple
crispyboy
Hello everyone today i came across something very weird.
I brought a new bleed nipple as my old one snapped so i screwed it in then started bleeding the brake as normal.
The then tightened the bleed screw enough for it not to leak and fluid came out of the end when i pumped the lever.
I then tightened it more and then it wouldent go anymore tighter and it still leaked out of the end hole
Very weird i dont understand why.
Any help
If this is for a disk brake you might be missing the ball bearing the bleed nipple tightens against to seal the fluid into the caliper. I haven't opened a Hope one yet (It's only a matter of time though, my brand new since January Hope trials disk has already leaked once but it was just the banjo fitting somehow loosening)...
