p_ruskin Posted March 20, 2010 Report Share Posted March 20, 2010 i have had my hope mono trial (rear) for about 3-4months now and the bolt that connects the hose to the piston constantly keeps coming loose nomater what i do to tighten it and the fluid leaks out and ruins my rotor and pads each time (it has happened around 3times now) have tried a new bolt but still nothing works , any sudjestions on what to do? thanks. Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted March 20, 2010 Report Share Posted March 20, 2010 i have had my hope mono trial (rear) for about 3-4months now and the bolt that connects the hose to the piston constantly keeps coming loose nomater what i do to tighten it and the fluid leaks out and ruins my rotor and pads each time (it has happened around 3times now) have tried a new bolt but still nothing works , any sudjestions on what to do? thanks. if you've replaced the bolts and it still does it, have you checked the threads where it screws into the caliper? Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted March 20, 2010 Author Report Share Posted March 20, 2010 yeah i even took it to supercycles, where i got it from, so they could have a look and they fixed it and got me a new rotor and pads again but it has happend again now so i dont know whats wrong with it. Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted March 20, 2010 Report Share Posted March 20, 2010 yeah i even took it to supercycles, where i got it from, so they could have a look and they fixed it and got me a new rotor and pads again but it has happend again now so i dont know whats wrong with it. if supercycles "fixed" it but it's gone again, then they didn't fix it properly (or you've tampered with it since they did it?) so tell them and they should do it properly for you. Quote Link to comment Share on other sites More sharing options...
AlexxRogers Posted March 20, 2010 Report Share Posted March 20, 2010 Get rid of it and get an Avid BB7. Can't go wrong with a decent set-up, and they can't leak or pop, less hassle, easier to set up. Alex. Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted March 20, 2010 Author Report Share Posted March 20, 2010 if supercycles "fixed" it but it's gone again, then they didn't fix it properly (or you've tampered with it since they did it?) so tell them and they should do it properly for you. yeah im guna send it back on monday, get it done again and hopefully they wont charge me for it. thanks for the help Quote Link to comment Share on other sites More sharing options...
paul112001 Posted March 20, 2010 Report Share Posted March 20, 2010 i have had my hope mono trial (rear) for about 3-4months now and the bolt that connects the hose to the piston constantly keeps coming loose nomater what i do to tighten it and the fluid leaks out and ruins my rotor and pads each time (it has happened around 3times now) have tried a new bolt but still nothing works , any sudjestions on what to do? thanks. If its the bolt that connects the hose to the caliper body it may be a dodgy copper olive/washer which is put there to stop leakage. Sometimes they are damaged because copper is quite soft and need replacing. If it is this you will need to rebleed the break. Try not to over tighten the bolt as this may cause damage to the washer. Hope this helps? Paul Quote Link to comment Share on other sites More sharing options...
p_ruskin Posted March 20, 2010 Author Report Share Posted March 20, 2010 If its the bolt that connects the hose to the caliper body it may be a dodgy copper olive/washer which is put there to stop leakage. Sometimes they are damaged because copper is quite soft and need replacing. If it is this you will need to rebleed the break. Try not to over tighten the bolt as this may cause damage to the washer. Hope this helps? Paul I will check that out thanks as i didnt replace the olive last time i had it done, i think that may be the problem thanks. but i need a rebleed anyway now, all the fluid has basicly gone out of it now, yeah thanks for the advice Quote Link to comment Share on other sites More sharing options...
Happydaze Posted March 20, 2010 Report Share Posted March 20, 2010 Had the same problem, renew banjo bolt and washers, do NOT over tighten. Problem solved. Good luck. Quote Link to comment Share on other sites More sharing options...
