Power Pad Backings
Boil some water in a pan, 5-8 mins of mega boiling water should be enough to break the glue seal. 2 pairs of pliers, 1 holding the pad and one holding the packing and pull apart gently. If it doens't work, boil it for longer.
You CAN put them in the oven, but last time I did that the pads bubbles and died.
ok, i was using water from the kettle, ill try boiling it in a pan.
thanks
