Julius Czar Posted March 18, 2010 Report Share Posted March 18, 2010 Hey, my front sprocket is rather bent, and I get a fat tight spot, which makes it hard to set up whats the best way to straighten it without damaging it? Cheers. Kieran Quote Link to comment Share on other sites More sharing options...
Muel Posted March 18, 2010 Report Share Posted March 18, 2010 You sure it's the sprocket? You always end up with tight and slack spots. Whats the spec? More than likely just that the tapers and the sprocket thread on the crank arm aren't concentric. Quote Link to comment Share on other sites More sharing options...
Julius Czar Posted March 18, 2010 Author Report Share Posted March 18, 2010 You sure it's the sprocket? You always end up with tight and slack spots. Whats the spec? More than likely just that the tapers and the sprocket thread on the crank arm aren't concentric. 116mm monty isis bb with a zhi 18t sprocket. But im pretty sure it is the sprocket, its like four years old, and its a really bad tight spot, like it will go really loose then really tight.. Quote Link to comment Share on other sites More sharing options...
Muel Posted March 18, 2010 Report Share Posted March 18, 2010 What are the cranks though? When sprockets bend it doesn't really effect chain legnth in my experience, because the circumference of the sprocket is still the same. Quote Link to comment Share on other sites More sharing options...
Julius Czar Posted March 20, 2010 Author Report Share Posted March 20, 2010 What are the cranks though? When sprockets bend it doesn't really effect chain legnth in my experience, because the circumference of the sprocket is still the same. Echo 6061 forged cranks? And a few teeth are missing too, think its time for a new sprocket Quote Link to comment Share on other sites More sharing options...
