Rowlly21 Posted March 18, 2010 Report Share Posted March 18, 2010 Hi I at the moment have vee brakes and was wourdering if to bother ( spend money) on changing the back one to Hs33's or just get some decent pads on a grind or tar What you think ? Quote Link to comment Share on other sites More sharing options...
AlexxRogers Posted March 18, 2010 Report Share Posted March 18, 2010 Decent Pads on a grind with a good set-up will do you nicely. no need for a HS33, Ali c will agree. Alex. Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted March 18, 2010 Author Report Share Posted March 18, 2010 Decent Pads on a grind with a good set-up will do you nicely. no need for a HS33, Ali c will agree. Alex. Cheers what pads would you sugest with a decent grind Andy Quote Link to comment Share on other sites More sharing options...
tdubz Posted March 18, 2010 Report Share Posted March 18, 2010 tnn v brake pads and a grind using a stone cutting disc good set up Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted March 18, 2010 Author Report Share Posted March 18, 2010 (edited) will they not wear away quikly with a grind as there £22 and im 13 ! Edited March 18, 2010 by Rowlly21 Quote Link to comment Share on other sites More sharing options...
Simpson Posted March 18, 2010 Report Share Posted March 18, 2010 Ali c will agree. LOLZ, "Decent pads and a grid?" How about Zoo greens on a grinded rim? Will that do? Sarcasm Quote Link to comment Share on other sites More sharing options...
TrialZonn Posted March 18, 2010 Report Share Posted March 18, 2010 If you don't want to change your brake then I would recommend the Heatsink Vee Pads on a light grind. I have the magura version of the yellows and they are amazing!They just won't slip! Quote Link to comment Share on other sites More sharing options...
Revolver Posted March 18, 2010 Report Share Posted March 18, 2010 If your frame has V-mounts, which it probably does if you're using one already, then the vee will be piles better than an evo mount setup, for less. If you've got 4bolt and adaptors, well, it's still cheaper just to buy some good pads. Quote Link to comment Share on other sites More sharing options...
Trials Punk Posted March 18, 2010 Report Share Posted March 18, 2010 i just got the soft echo pads from tarty, running them on a smooth rim. Just had a play about in the rain, and they hold almost as much as I would ever need them too! Quote Link to comment Share on other sites More sharing options...
Ali C Posted March 18, 2010 Report Share Posted March 18, 2010 as mentioned, if your frame has vee mounts, you would be daft to put a maggie on there with evo mounts. Even if you didn't like your current brake, its not expensive to get some good avid arms and lever, then some nice TNN pads and some bmx linear cable get all that and you'll be laughing. Quote Link to comment Share on other sites More sharing options...
Rowlly21 Posted March 19, 2010 Author Report Share Posted March 19, 2010 Cheers all Quote Link to comment Share on other sites More sharing options...
