Theo Posted March 16, 2010 Report Share Posted March 16, 2010 Im using echo sl cnc cranks with a bash ring, I didn’t put the spacer on as instructed. Also it’s not the threads they are fine. Is there a reason they are coming loose after about 20mins riding? Its the crank without the bash ring on that’s coming loose more often if this helps, but the other is still doing it only more slowly and less frequently. If you need pics just let me know. Cheers Theo Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted March 16, 2010 Report Share Posted March 16, 2010 did you torque them up properly and grease the splines? I put mine on a year and a half ago and they've never felt loose since then Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 16, 2010 Report Share Posted March 16, 2010 Are the tapers buggered? Threads knackered on BB or bolt? Washer not seating properly on the BB? Bolt not seating properly on the crank? Bolt bottoming out on the BB axle? Quote Link to comment Share on other sites More sharing options...
Theo Posted March 16, 2010 Author Report Share Posted March 16, 2010 did you torque them up properly and grease the splines? I put mine on a year and a half ago and they've never felt loose since then Yep did all of that Are the tapers buggered? nope Threads knackered on BB or bolt? nope its all new Washer not seating properly on the BB? should think so, but will checkBolt not seating properly on the crank? yep this is fineBolt bottoming out on the BB axle? nope checked lengths Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted March 16, 2010 Report Share Posted March 16, 2010 All new cranks should be expected to come loose. You just need to keep an eye on them, tighten them every 15 mins and they'll soon stop being annoying. Quote Link to comment Share on other sites More sharing options...
Theo Posted March 16, 2010 Author Report Share Posted March 16, 2010 All new cranks should be expected to come loose. You just need to keep an eye on them, tighten them every 15 mins and they'll soon stop being annoying. Thats what I was hoping for, thanks! Quote Link to comment Share on other sites More sharing options...
