Trialtech Handlebars
mr ailsbury
Right heres my dillema,
I've been thinking about trying some Trialtech Sport riser bars for a while now, but i've been advised not to as they're really snap happy... Is this true?
Just wanted to get peoples opinions really 'cause the bikes i've ridden with them on felt nice but I can't afford to buy something if its going to snap quickly :/
cheers
Sounds like rubbish to me, Trialtechs are stronger than some other bars out there! Looking at the bars that Tarty sell, I'd say the only stronger bars would be either Inspired or maybe Renthal. 7075 aluminium is the strongest material used for trials bars, and all decent bars will use a similar design with a triple butted profile. There will be small differences in wall thickness and obviously shape/width which will account for the different weights. What I'm saying is because bars are so simple the weight is a good guide to the potential strength, if they are the same material and width. Take for instance Viz bars (10% lighter) and Echo SLs (20% lighter), I'd be very surprised if these were as strong as Trialtechs...
For the record my Trialtech bars snapped after 6 months, but I am a hard rider with a history of snapping bars. The only bars that have lasted me were heavy DH bars or '05 zoo bars (over 2 years without failure, they weighed about 330g). I've now switched to Inspired bars which are a bit heavier than Trialtechs, no problems so far. I made a topic about them which you can read here
Apparently there was a slight issue with the first batch where they weren't made to the correct spec, but since that they've been totally fine. I've been at Tartybikes for 6 months now and we've sold a hell of a lot of these bars and haven't had a single set back for any reason at all. They're definitely not 'snap happy', and I wouldn't think you'd have a problem with them at all.
He said that something like 25 pairs snapped in the first 4/5 months
Pshh how would anyone apart from the retailer or manufacturer know that?
get some Monty 221 Ti risers in black, the ones that say "exclusive" on them.
I've used Trialtechs and the Monty's are much better
I have the same bars but in silver ti colour...they ride much nicer, same geo as the Viz pro 720's but a tad wider :)
yeah, except he hasn't got trialtech bars...
Sure he did at one point?
The 221 Ti bars are 30mm narrower than the Viz 720s, unless that's what you meant? I thought you were trying to say the 221 Ti risers were wider.
The 221 bars are almost £20 more than the TT bars, but you definitely don't get £20 more bar...
Apparently there was a slight issue with the first batch where they weren't made to the correct spec, but...
... even that batch of a few hundred was completely fine, apart from two sets. One was Matt Burrows and one was Ben Slinger, both broke where the brake lever clamped to the bars (stress riser) if I remember correctly.
Apart from those two I've never heard of another set bending or breaking, even the prototype sets which were 10% lighter than production!
