Bike Problem....Front End Squeaking
It squeeking could be a number of things, but tell us WHEN it squeaks and how it squeaks. Does it squeak when you turn the bars, or when you are rolling, or only under heavy braking, etc.
hi there
thanks for the reply it squeaks when your rolling but leaning over the bars i have greased the headset becuase the last lot was off, this has work to a point but round the head set it squeaks a tiny little bit...new cups mabye ??
hi there
That sounds like it could be a flared headtube, which sadly would mean a new frame.
Look at the forks very very closely for cracks and such first,remove the stem then hold the forks securely and rock them backwards and forward.
They will move anyway but watch the headset cups very closely, if they move in the frame you have a problem.
Many years ago a friend had a creaky front end, ignored it, and a day later his fork steerer snapped. If you're checking the headset, might be worth going over your forks closely at the same time?
T
Thanks for that bro
ive been riding with the creek for a while now and ive only just joined up on here so i was like 'No harm in trying to put up a thread' so ill try that becuase i like my face how it is lol
thanks :D
