Hs33 Pads
hi i have just got an rear hs33 brake and i dont know what pads i should use i ride alot of street but when the weather is good i ride natural
i am looking for a pad that works well in both street and natty and also since we live in the uk i also need them to work in the wet or dry as well
so basically im looking for a good allround pad. :)
Why would you even ask this question when all the lads you ride with who run rear maggie, run TNNs on a harsh grind? and there all beast brakes, all weather....
There's your answer
Thanks BAZZ but i forgot wat they were.ill order some but the onza citrus will hav to do for tomorrow.
