Cranks
crispyboy
Sorter are better for rolling moves, don't have to pedal as much, but for static moves you need to be able to put more power in to get the same result as you would with longer cranks, shorter cranks simply increase your gearing slightly as it alters the the radius between the centre of the cranks and your pedal.
