i like cunning stunts Posted March 7, 2010 Report Share Posted March 7, 2010 (edited) Had a nightmare today on the new bike basically couldnt tension the chain properley for longer than five mins. I have a zhi rear hub and i have to run the snail cams on the outside of the frame but it just isnt holding the wheel in place this is because the cams are sitting on the bolts right? and not the axle..? Anyone know a solution to this or will i have to grind the spacers down so that the snails will run on the inside of the frame?? Edited March 7, 2010 by Jake-Ansell Quote Link to comment Share on other sites More sharing options...
