multi tasking male Posted March 7, 2010 Report Share Posted March 7, 2010 i have a ashton effect with the old evo adapters on the back and there a pain to setup, went to water bleed my brake today and water kept leeking out of the hole where you take out the screw out to bleed it on the lever and did it up to tight and the metal and threads around it snaped so there is a chunk missing out of the lever but the calipers, hose,lever and internal are all fine. its a 04 model with a hose lengthe for the back but a right hand lever but i just fliped the lever over the other wy to put it on the left hand. how much do you think i would get for it all, hole brake with chunk from the lever, old evo adapter kit and a bodge evo adapter booster ? chris Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted March 7, 2010 Report Share Posted March 7, 2010 Put it on ebay and find out Quote Link to comment Share on other sites More sharing options...
Billsy Posted March 9, 2010 Report Share Posted March 9, 2010 Ebay is probably your best bet, however, you should ask around, although i'm guessing not alot as it is an 04 model after all, but good luck too you, i hope you sell it. Quote Link to comment Share on other sites More sharing options...
multi tasking male Posted March 11, 2010 Author Report Share Posted March 11, 2010 Ebay is probably your best bet, however, you should ask around, although i'm guessing not alot as it is an 04 model after all, but good luck too you, i hope you sell it. Thats what im worried about, if i sell it is there much point because if i wont get much then im looking to get a new frame with maggy mounts on in the future so if i wouldnt get much i would keep it and use it for that. What kind of price range are you thinking as not much ? Ebay is probably your best bet, however, you should ask around, although i'm guessing not alot as it is an 04 model after all, but good luck too you, i hope you sell it. Quote Link to comment Share on other sites More sharing options...
davey1991 Posted March 11, 2010 Report Share Posted March 11, 2010 Ebay is probably your best bet, however, you should ask around, although i'm guessing not alot as it is an 04 model after all, but good luck too you, i hope you sell it. 04's are very desirable and in some cases worth more second hand than the new brakes. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 12, 2010 Report Share Posted March 12, 2010 dependant on condition... £17-28 I reckons. Quote Link to comment Share on other sites More sharing options...
jordan allsop Posted March 14, 2010 Report Share Posted March 14, 2010 Put it on ebay that your best bet or just ask around. Quote Link to comment Share on other sites More sharing options...
