Badly Timed Riding :P
Toby
so today at clacton was doing an up gap to a slanted downward rock, so i had to plant the front wheel right down, front missed and frame took full force and for some reason moved my protection out the way and this is what happened to the frame:
so i think its time for a new frame :P had this one for almost a year and was still going strong oh well :) saying that the rear end was just too flexy
Edited by Toby
Dent/crack caused at the same time, other wise rest of the downtube was in perfect condition, im not going to bugger about with getting it welded, new rockman frame on order already and i was unhappy with the rear end flex of the bike meaning i had to set up the brake in a particular way to stop the brake rubbing when putting power down, but other than that its been a great frame lasted alot longer than i exspected and would of lasted longer if not for this accident :P
Edited by Toby
You're kidding right? A £20 weld job and a bit of effort sucking/pushing that dent out and the frame will be right as rain, whereas at the moment it's unridable...
Well as i said i wasnt happy with the flexyness of the bike which was affecting the rear brake anyway, I had been considering a new frame due to this problem
Still be weak as buggery if not heat treated...although still worth doing I guess
This shows how much cheese Koxx use in their frames. :P
Unlicky though, wouldnt really expect a £800 frame to do that though.
Why not? Twatting a weld against a rock on a super light top of the range comp frame isn't gonna end well.
Thats like saying 'this F1 car costs millions, cant believe it fell to bits after I crashed into a wall'
it shouldnt tear away like that, very poor welding. tubing looks very thin too.
as leistonbmx said, it was bashed really hard and the metal is made from chedder, got my akali now mostly built up, need to cut my steerer tube down and get some bb cups/bearing off a friend then i will post pics up :)
Edited by Toby
It was bashed on a rock. It's a weak material. So I fail to see how it's bad welding.
yea i no he banged it on a rock. the weld should not tear away from the parent metal like that thou. im not going to go in to one about welding but thats a sign of a bad weld.
