Theo Posted March 5, 2010 Report Share Posted March 5, 2010 Right. I use a cd to line the pads up straight to the rim, but when I tighten the bolts, after about 5-10 mins riding they seem to slip back so I loose some braking power, sometimes I loose more more than others. I have tried tightening them quite a bit but i dont want to tear off the threads. Is this normal, if not what could be causing it? (pics below) Cheers Theo sorry if they are a bit blury, too tired to play with camera settings! Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted March 5, 2010 Report Share Posted March 5, 2010 i bet your bolts are too long and bottoming out on the frame. Quote Link to comment Share on other sites More sharing options...
DEZ Posted March 5, 2010 Report Share Posted March 5, 2010 (edited) i bet your bolts are too long and bottoming out on the frame. snap check the length out and also is the clamp is well clamped through should touch if not there defo too lose if they are too long you can either be brave and cut them or get shorter ones looks like the booster bolt might cause a problem try running with out it and see how it gos Edited March 5, 2010 by DEZ Quote Link to comment Share on other sites More sharing options...
moreton rider Posted March 5, 2010 Report Share Posted March 5, 2010 Right. I use a cd to line the pads up straight to the rim, but when I tighten the bolts, after about 5-10 mins riding they seem to slip back so I loose some braking power, sometimes I loose more more than others. I have tried tightening them quite a bit but i dont want to tear off the threads. yeah do you still have the little plastic washer things on the cylinders beacuse if you took the of and havent put them back ont it wont tighten fullly? otherwise you might have to file dow your mounts to make sure it tightens . if none of that works you need a heliciol hope this helped. Quote Link to comment Share on other sites More sharing options...
Theo Posted March 5, 2010 Author Report Share Posted March 5, 2010 (edited) snap check the length out and also is the clamp is well clamped through should touch if not there defo too lose if they are too long you can either be brave and cut them or get shorter ones looks like the booster bolt might cause a problem try running with out it and see how it gos humm, i will have a look, didnt understand your second bit though, didnt make much sense to me the bolts are the ones that came with the bike apart from the booster (gold) ones. would this still effect it? - will do! yeah do you still have the little plastic washer things on the cylinders beacuse if you took the of and havent put them back ont it wont tighten fullly? otherwise you might have to file dow your mounts to make sure it tightens . if none of that works you need a heliciol hope this helped. I dont think i have the plastic bits on. will double check now. "file dow your mounts" which bit do you mean? just the bolts? Edited March 5, 2010 by Theo Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted March 5, 2010 Report Share Posted March 5, 2010 humm, i will have a look, didnt understand your second bit though, didnt make much sense to me the bolts are the ones that came with the bike apart from the booster (gold) ones. would this still effect it? I dont think i have the plastic bits on. will double check now. "file dow your mounts" which bit do you mean? just the bolts? you dont have the plastic spacers around the cylinder? that is your initial problem. and if the gold bolts are too long, then yeah they will also be a problem Quote Link to comment Share on other sites More sharing options...
Theo Posted March 5, 2010 Author Report Share Posted March 5, 2010 (edited) you dont have the plastic spacers around the cylinder? that is your initial problem. and if the gold bolts are too long, then yeah they will also be a problem Right. So i need them on. haha. Turns out they are on. How i didnt remember i dont know they are massive. I checked the lengths and the booster bolts have the same length of threads as the stock bolts that came with the bike. so its not the length any other ideas anyone?. I thought it could be the rubber bit. do the clamps need to be perfectly in line with the rubber bit on my maggies, its slightly off. Edited March 5, 2010 by Theo Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted March 5, 2010 Report Share Posted March 5, 2010 This may not be related but i can see (from looking at the gap between the brake pads and pistons) that you've adjusted the tpa (that red adjustment on your brake lever) all way to max+ before fitting and adjusting the pads. If this is the case with the tpa, you need to re-adjust it back all the way to min- before fitting the pads again. Ps, use a credit/debit card instead of a cd or checkout adam@tartbikes video how-to. Quote Link to comment Share on other sites More sharing options...
rab shropshire Posted March 5, 2010 Report Share Posted March 5, 2010 i had the same problem using tensile ofset mounts, im affraid i dont have a quick fix just get some regular maggy mounts and you should be fine Quote Link to comment Share on other sites More sharing options...
Theo Posted March 5, 2010 Author Report Share Posted March 5, 2010 This may not be related but i can see (from looking at the gap between the brake pads and pistons) that you've adjusted the tpa (that red adjustment on your brake lever) all way to max+ before fitting and adjusting the pads. If this is the case with the tpa, you need to re-adjust it back all the way to min- before fitting the pads again. Ps, use a credit/debit card instead of a cd or checkout adam@tartbikes video how-to. great man, well noticed. i think i have. So would this make it slip? or loose power? Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted March 5, 2010 Report Share Posted March 5, 2010 great man, well noticed. i think i have. So would this make it slip? or loose power? lose power. looking at the pics again you definitely have adjusted the tpa to max+ before fitting and adjusting the pads. adjust the tpa back to min- and use a credit or debitcard instead of a cd disc. Quote Link to comment Share on other sites More sharing options...
Theo Posted March 5, 2010 Author Report Share Posted March 5, 2010 lose power. looking at the pics again you definitely have adjusted the tpa to max+ before fitting and adjusting the pads. adjust the tpa back to min- and use a credit or debitcard instead of a cd disc. Thanks, will do. great help mate by the way just out of interest, how does the tpa work, and what does tpa stand for? thanks again Theo Quote Link to comment Share on other sites More sharing options...
Rusevelt Posted March 5, 2010 Report Share Posted March 5, 2010 Thanks, will do. great help mate by the way just out of interest, how does the tpa work, and what does tpa stand for? thanks again Theo No idea dude, id assume that there is some kind of mechanical push rod system in the lever and when adjusted via the tpa this in turn forces the oil further down the cable to push the slave pistons (those little tiny plastic rods that push the brake pads) or something like that, im just guessing. Im sure OBM or Adam will explain if they read this thread. Quote Link to comment Share on other sites More sharing options...
Theo Posted March 5, 2010 Author Report Share Posted March 5, 2010 No idea dude, id assume that there is some kind of mechanical push rod system in the lever and when adjusted via the tpa this in turn forces the oil further down the cable to push the slave pistons (those little tiny plastic rods that push the brake pads) or something like that, im just guessing. Im sure OBM or Adam will explain if they read this thread. cool, just sorted it out now, working fine. looking forawd to riding with decent breaks tomorrow. Thanks Theo Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted March 6, 2010 Report Share Posted March 6, 2010 Thanks, will do. great help mate by the way just out of interest, how does the tpa work, and what does tpa stand for? thanks again Theo TPA = Turbo Pad Adjustment. basically, when you turn the tpa, you are infact turning a screw, this screw will be pushing a rod into the lever piston. and due to the nature of the brake will put pressure through the whole system and moving your pads very slightly closer to the rim. this can lead to the tpa breaking over time, a pain in the arse to set up as the pad calipers can switch which gets pushed closer to the rim. it isnt designed to be used for setting the brake up. its more if you are out riding and you need some adjustment you should use it till the end of the ride, then when you get home, take the tpa off and set the brakes up properly, maybe even a re bleed Quote Link to comment Share on other sites More sharing options...
sstein Posted March 7, 2010 Report Share Posted March 7, 2010 i had the same problem using tensile ofset mounts, im affraid i dont have a quick fix just get some regular maggy mounts and you should be fine It is the tensile mounts, there are two ways to fix it, one put something under the plastic o-ring to increase it's size, the other (and more recommended one) is to file down the tabs on the mounts a little so they sit closer together! Quote Link to comment Share on other sites More sharing options...
Theo Posted March 7, 2010 Author Report Share Posted March 7, 2010 (edited) the other (and more recommended one) is to file down the tabs on the mounts a little so they sit closer together! right! i still have the same problem so this info should be pretty helpfull, just to check, are the tabs on the mounts the slightly raised bits on the clamps? I dont want to be filing away at the wrong thing. Thanks, Theo Edited March 7, 2010 by Theo Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 7, 2010 Report Share Posted March 7, 2010 right! i still have the same problem so this info should be pretty helpfull, just to check, are the tabs on the mounts the slightly raised bits on the clamps? I dont want to be filing away at the wrong thing. Thanks, Theo Yup, where the two mounts contact each other, the top mounts have a small lip. remove a little material from this Quote Link to comment Share on other sites More sharing options...
Theo Posted March 7, 2010 Author Report Share Posted March 7, 2010 Yup, where the two mounts contact each other, the top mounts have a small lip. remove a little material from this Thanks mate Quote Link to comment Share on other sites More sharing options...
i like cunning stunts Posted March 7, 2010 Report Share Posted March 7, 2010 Thanks mate I have this same problem now with the same mounts.. I even ground the lips off the mounts today but it still slips so i have gave up and a v brake is going on this week...;} Quote Link to comment Share on other sites More sharing options...
Theo Posted March 7, 2010 Author Report Share Posted March 7, 2010 I have this same problem now with the same mounts.. I even ground the lips off the mounts today but it still slips so i have gave up and a v brake is going on this week...;} what you getting? Quote Link to comment Share on other sites More sharing options...
i like cunning stunts Posted March 7, 2010 Report Share Posted March 7, 2010 what you getting? Some sort of avid and dont know which pads yet either the rock cnc or the tnn's?.. Quote Link to comment Share on other sites More sharing options...
Theo Posted March 7, 2010 Author Report Share Posted March 7, 2010 Some sort of avid and dont know which pads yet either the rock cnc or the tnn's?.. sounds good, good luck with that! Quote Link to comment Share on other sites More sharing options...
sean1993 Posted March 7, 2010 Report Share Posted March 7, 2010 oh my god yeah .... i put tensile ones on what a heap of sh*t ..... no offence to all that use them. they slipped and sliped and put my magura ones back on and there sooooo much better. only put the tensile ones on because they look flash lol. Quote Link to comment Share on other sites More sharing options...
JamieWilliams Posted March 7, 2010 Report Share Posted March 7, 2010 My mate had the same thing happen with his tensile clamps How to fix it \/\/ Take the plastic spacers around the cylinder off, Put some insulation type around the cylinder then put the plastic spacers back on. Job done hope this helps Jamie Quote Link to comment Share on other sites More sharing options...
