Luke.P Posted March 5, 2010 Report Share Posted March 5, 2010 atm not runing a front brake as the lever has fudged.. So was wondering if it would be cheaper to buy a V and adapaters for my 4 bolt mounts rather than buying a brand new hs33 Just wonder what would be the best adapters to buy from (tarty), arms, lever. cable, pads : guess avid..? Quote Link to comment Share on other sites More sharing options...
ogre Posted March 5, 2010 Report Share Posted March 5, 2010 22 onza vee dapters 11 sd7 lever 28 sd7 arms 04 cable comes in at £65 which is dearer than a magura, but front vee is SO MUCH BETTAR i didn't factor in pads but it's worth mentioning with vee pads the CNC backed pads are cheaper than HS33 counterparts so you get a bit more for your money (and you save money with refills too) 18 heatsink yellow pads Quote Link to comment Share on other sites More sharing options...
Luke.P Posted March 5, 2010 Author Report Share Posted March 5, 2010 22 onza vee dapters 11 sd7 lever 28 sd7 arms 04 cable comes in at £65 which is dearer than a magura, but front vee is SO MUCH BETTAR i didn't factor in pads but it's worth mentioning with vee pads the CNC backed pads are cheaper than HS33 counterparts so you get a bit more for your money (and you save money with refills too) 18 heatsink yellow pads Ahhh sounds good, might aswell do that then Thanks for ur help Quote Link to comment Share on other sites More sharing options...
Skoze Posted March 5, 2010 Report Share Posted March 5, 2010 Vees and jam. Quote Link to comment Share on other sites More sharing options...
