3dd Posted March 5, 2010 Report Share Posted March 5, 2010 (edited) I was planning to go for a because 24 frame sometime this/next month and wanted to try a double disc on it. I have a stock so will be using a lot of parts of it like ffw, cranks, headset, stem, bars, etc. But there isn't a lot of choice in a 135mm disc hubs, except for try-all, which is out of stock at tarty anyway. And also saw the zhi rear disc hub 135 on trialparts.net. Is there any other alternatives? Shame I sold my Chris King disc hub, would have a good use to it... And another question about forks: I am using koxx forks at the minute, will those be ok for 24? Thanks Ed Edited March 9, 2010 by 3dd Quote Link to comment Share on other sites More sharing options...
josh barker Posted March 5, 2010 Report Share Posted March 5, 2010 koxx forks wont be a problem, you may as well buy a pro2 trials rear hub, disc ready too and cheaper than the rear try all disc hub. and a front screw on cog is only about 15-20quid so you may as well go for a rear pro2 hub Quote Link to comment Share on other sites More sharing options...
3dd Posted March 5, 2010 Author Report Share Posted March 5, 2010 (edited) Was thinking that, but only 48 engadgements. You can feel a difference between 48 and 108. I have a ffw already, so it would be exactly the same money wise. There is Echo SL on selectbikes but it's under "coming soon" state. Edited March 5, 2010 by 3dd Quote Link to comment Share on other sites More sharing options...
