mike425 Posted March 4, 2010 Report Share Posted March 4, 2010 Hi Guys, After some advice, I just noticed that bikedock are selling brand new Hope Mono trials front brakes for £70!! Catch is they are the Koxx 190mm rotor standard. This got me thinking, I am using Echo forks which as far as I know have a standard size IS spacing. Does anyone know of an easy way to make this Koxx brake fit a 185mm rotor for my bike? I am unsure as to whether this has a custom caliper or not on the brake. Thanks Mike Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 4, 2010 Report Share Posted March 4, 2010 Hi Guys, After some advice, I just noticed that bikedock are selling brand new Hope Mono trials front brakes for £70!! Catch is they are the Koxx 190mm rotor standard. This got me thinking, I am using Echo forks which as far as I know have a standard size IS spacing. Does anyone know of an easy way to make this Koxx brake fit a 185mm rotor for my bike? I am unsure as to whether this has a custom caliper or not on the brake. Thanks Mike That won't fit I dont think...you may be able to get/make an adaptor to get it up to 200 though? Quote Link to comment Share on other sites More sharing options...
thompo Posted March 4, 2010 Report Share Posted March 4, 2010 (edited) Is the Caliper not the same and koxx forks incorporates a +10/+30mm mount? Use the caliper, buy a new rotor, New brake for £90? Edited March 4, 2010 by thompo Quote Link to comment Share on other sites More sharing options...
mike425 Posted March 4, 2010 Author Report Share Posted March 4, 2010 Yeh, I have a 203 and a 180 rotor lieing around so wouldn't have to buy one. It does not say on their website what caliper it is. Say it is a caliper for a 160mm rotor, the koxx forks are +30mm that means you would have to run 190mm? So I am thinking buy it, get the hope adaptor to run a 160mm caliper on a 180mm rotor and I have a new brake for 80 quid? Is there logic in this or am I miles out? The only stumbling block I can see is wether or not the Kox forks are +10 or +30? Mike Quote Link to comment Share on other sites More sharing options...
thompo Posted March 4, 2010 Report Share Posted March 4, 2010 http://www.tartybikes.co.uk/product.php?product_id=193&category_id=40 Quote Link to comment Share on other sites More sharing options...
Matthew62 Posted March 4, 2010 Report Share Posted March 4, 2010 Yeh, I have a 203 and a 180 rotor lieing around so wouldn't have to buy one. It does not say on their website what caliper it is. Say it is a caliper for a 160mm rotor, the koxx forks are +30mm that means you would have to run 190mm? So I am thinking buy it, get the hope adaptor to run a 160mm caliper on a 180mm rotor and I have a new brake for 80 quid? Is there logic in this or am I miles out? The only stumbling block I can see is wether or not the Kox forks are +10 or +30? Mike If its a caliper for a 160mm rotor then you'll be fine. You just need either a 160 rotor or a plus 20mm adapter to run 180. Quote Link to comment Share on other sites More sharing options...
