Magura Mount Question.
davey90
Hi, I have an old 2002 T-Pro frame, it has 4 bolt mounts but the centre to centre of the two bolt holes is 65.5mm whereas on my Woodstock the centre to centre of the two bolt holes is 55.5mm, are the older 4 bolt clamps still available for the larger mounts ?
Are you sure they are not the dual fitting mounts which we fitted for a couple of years. They had an extra pair of holes in a groove in the well of the fitting. You then got a small alloy block with a hole in it which fitted either at the bottom of the slot if using a 20" back wheel or at the top of the slot if using a 19" back wheel. You then used an extra long bolt on that end. You cannot use the frame with Maguras without the little block. If you haven't got the blocks you are welcome to contact us if you cannot source them. Don't want to be accused of advertising.
Like on the old t-birds :) I'm sure the offset was more than ten mm?
Edit: It would be 20 - 19" = 1" diameter...so 0.5" radius :. 12.25mm
Edited by Alex Dark
Measured from centre to cenre on the holes and I used a steel rule so no dodgy ruler stuff going on, yeah there are holes in between the mounts aswell so it sounds like it is the dual fitting ones. Will email you about getting the blocks. Thanks for the help.
If not they're easy enough to make :)
