Snapping Viz Rear Axles ?
Alex Dark
Mate of mine snapped around 3 of these Viz Rear mod axles, and we realised they were all dying on the threads...whether this is because the actual thread caused a big enough weak spot, or the compressive axle ends forced the axle apart slightly we're not sure....however; he used a non threaded axle that was the same dimensions, then filed out the axle ends to accept it. Trouble is I can't remember which one it is :P
The T-master 07 fits the Viz hub directly, threads and all....
Can anyone tell me if the Trialtech / Rockman / or most likely the T-master 06 will fit the Viz..... I guess the only dimension that matters is that between the bearing flanges?
Cheers, Alex
Cheers, Alex
I had the same problem, snapped 2 axles. I used a t-pro 06 when tartys didnt have the right one in stock, only problem is i had to use big nuts for spacers since there re no threads. It didnt break, and i rode it for like 3 months.
:P
Awesome, Cheers dude :)
