Pro 2 In Ozony Curve?
Damon W
Yeah it's possible, you just need to machine some inserts that screw into the axle ends which have an M6 thread down the centre, so you can run M6 bolts like the try-all, trialtech etc use. My brother's running his king set-up like this in his curve and also used it on the cannibal before.
No need to drill such a nice frame this way
Send us a message if you need anymore info dude! (Y)
Edited by court
QR would work fine....The axle is held so securely in the bolt through dropouts :)
it doesnt, tried it in my canibal 3 (same dropouts). drill out the end of your axle then tap it (m6 thread) shuv a bolt through sorted, did this with my king. No problems at all
Was it a quick release king?
