Free Wheel Problem
shetlandtrialsrider
It's probably your cranks as much as anything - some cranks have the threads not perfectly concentric, so you'll get that 'wobble' in your chain tension when you spin your cranks. I've changed cranks 3 times over the past few months, and every time there's been different amounts of wobble. My Atomz cranks on my Premier were nuts, just seemed to get a bad set that had a massive change in tension.
So yeah, changing freewheel probably won't really do all that much in all honesty. If it's not changing tension massively, it may be worth trying to live with it.
Every ffw has this problem, its due to the threads.
Or, possible a really bad chain line or bent teeth, get a 60 click or a sl, and never look back, apparently.
ok buts gotten bad recently and it seems to wobble side to side as well. I cant even spin the cranks backwards to try and do crank spins they just stop in the same spot.
thanks for such a quick reply lol :D
oh ok its just really annoying lol :P
Sounds like it's the cranks to me, not the freewheel, although are you running an ACS claw? I'd change the cranks and freewheel sharpish. :P
I am not sure which free wheel im running just the stock one that came with the bike.
Anyone know some good cranks which will work with the tensile 60 click or other???
