Snail Cams
LukasMcNeal
The Echo TRs are so good! Definitely the best snail cams out there. I found with fully toothed snail cams I couldn't quite get my setup right, in that I needed a sort of half notch. Ads talked me into getting the TRs, and they're streets ahead of all the others. I was sort of skeptical of the micronotch system at first, but it really does work. They feel as easy to setup just where you want as smooth cams, but hold in place like toothed ones. All good (Y)
What's the difference between the sl and tr cams then Mark?
