trialsrider.chris Posted February 26, 2010 Report Share Posted February 26, 2010 (edited) hi everyone i really need some help i cant get hold of a onza sealed disk hub and wonderd if the echo tr 2010 disk hub would fit in the onza limey 320 frame .?? and would the disk sit right?? help apriciated . chris Edited February 26, 2010 by trialsrider.chris Quote Link to comment Share on other sites More sharing options...
Mark W Posted February 26, 2010 Report Share Posted February 26, 2010 You'd be better off with the V!Z disc hub or the Monty '07 221Ti hub with that frame. Monty's one would be ideal 'cos you'd potentially need to run some spacer to stop your frame having to pull in further (with the hub being slightly narrower than standard), which would mean you could space your drive-side out a bit, giving you better chain clearance on that frame too. The Echo TR would probably be a bit of a whopper without stretching your frame out a bit. Quote Link to comment Share on other sites More sharing options...
trialsrider.chris Posted February 26, 2010 Author Report Share Posted February 26, 2010 You'd be better off with the V!Z disc hub or the Monty '07 221Ti hub with that frame. Monty's one would be ideal 'cos you'd potentially need to run some spacer to stop your frame having to pull in further (with the hub being slightly narrower than standard), which would mean you could space your drive-side out a bit, giving you better chain clearance on that frame too. The Echo TR would probably be a bit of a whopper without stretching your frame out a bit. thanks but why cant tarty get the onza sealed one in stock?? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted February 26, 2010 Report Share Posted February 26, 2010 thanks but why cant tarty get the onza sealed one in stock?? As Mark said on the phone, Onza have none in stock. Quote Link to comment Share on other sites More sharing options...
josh barker Posted February 26, 2010 Report Share Posted February 26, 2010 viz hub would do mint, same dimensions as the onza hub (i think) Quote Link to comment Share on other sites More sharing options...
trialsrider.chris Posted February 26, 2010 Author Report Share Posted February 26, 2010 viz hub would do mint, same dimensions as the onza hub (i think) kool cheers mate have you got the 320?? if u have what rear hub to you have?? Quote Link to comment Share on other sites More sharing options...
Mark W Posted February 26, 2010 Report Share Posted February 26, 2010 It is indeed. And like Ali and I said on the phone - unless you ring around individual shops, I doubt you'll be able to find one of those sealed Onza disc hubs anywhere. If Onza/Moore Large themselves don't have them in, then it's just a case of finding if there are one or two lying around somewhere. Quote Link to comment Share on other sites More sharing options...
trialsrider.chris Posted February 26, 2010 Author Report Share Posted February 26, 2010 It is indeed. And like Ali and I said on the phone - unless you ring around individual shops, I doubt you'll be able to find one of those sealed Onza disc hubs anywhere. If Onza/Moore Large themselves don't have them in, then it's just a case of finding if there are one or two lying around somewhere. ive rang moore large and they say that they will have them in for the middle of march . so ill wait til then and then i will ring you guys at tarty for some wheels built up . thanks for your help chris Quote Link to comment Share on other sites More sharing options...
