nestorthegoon Posted February 25, 2010 Report Share Posted February 25, 2010 hi ive just bought a 20" gu st frame but the down tube has a crack in it only thing is the downtube is welded to the top tube so will this crack effect strength or am i guna have to get it welded? ty for replies Quote Link to comment Share on other sites More sharing options...
Muel Posted February 25, 2010 Report Share Posted February 25, 2010 Without pics we can't know. But generally speaking if a frame cracks, it's because that area gets strained a lot, so it will need welding. Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted February 25, 2010 Report Share Posted February 25, 2010 Without pics we can't know. But generally speaking if a frame cracks, it's because that area gets strained a lot, so it will need welding. Or replacing depending on the size and place of the crack. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 25, 2010 Report Share Posted February 25, 2010 I hope your downtube snaps and you die. Have I missed soemthing? When is it okay to say this to someone?! Anyway, yeh the downtube is a pretty critical area. Stop-drill it (2mm drill at each end of the crack ) see if it spreads...if so then welding is your only option, but bear in mind the area surrounding the weld will be only 20% of the strength of the original material...so it will probably crack there again. Quote Link to comment Share on other sites More sharing options...
nestorthegoon Posted February 25, 2010 Author Report Share Posted February 25, 2010 Have I missed soemthing? When is it okay to say this to someone?! Anyway, yeh the downtube is a pretty critical area. Stop-drill it (2mm drill at each end of the crack ) see if it spreads...if so then welding is your only option, but bear in mind the area surrounding the weld will be only 20% of the strength of the original material...so it will probably crack there again. extremely helpful thanks mate! Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted February 25, 2010 Report Share Posted February 25, 2010 How about everyone just stops. Reported Quote Link to comment Share on other sites More sharing options...
quick_spider Posted February 25, 2010 Report Share Posted February 25, 2010 Spam cleared and warnings dished out. Welcome to trials-forum! Don't be put off by the muppets who posted crap. Quote Link to comment Share on other sites More sharing options...
nestorthegoon Posted February 25, 2010 Author Report Share Posted February 25, 2010 Spam cleared and warnings dished out. Welcome to trials-forum! Don't be put off by the muppets who posted crap. thanks alot i duno what there problem was? Quote Link to comment Share on other sites More sharing options...
JT! Posted February 26, 2010 Report Share Posted February 26, 2010 Did you buy it 2nd hand, did you know it had a crack in it? Quote Link to comment Share on other sites More sharing options...
PeanuckleJive Posted February 26, 2010 Report Share Posted February 26, 2010 I read the title and thought you meant you'd swapped some crack for a GU Is it good crack? The downtube isn't a good area for a crack. can you get pics? a picture of the exact area/ size/ spread would really be helpful Quote Link to comment Share on other sites More sharing options...
