J Trials 31 Posted February 23, 2010 Report Share Posted February 23, 2010 (edited) Ok, first I know something is wrong but not what. It is really hard to pedal and it feels like the chain is too tight or something, but I checked the chain and it's no where near tight. When I get off and pedal it forwards it stops really quickly and seems like my pads are rubbing, but it's not that either. So I'm figuring it is either my hub or fw. Can anyone confirm my troubles? I need to get a new hub sometime anyway, but I don't have the cash for that right now, but if it's the fw I have one of those laying around I can throw on. Thanks for the help, Jordan Edited February 23, 2010 by J Trials 31 Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 23, 2010 Report Share Posted February 23, 2010 Over tightened hub bolts? snailcams binding on the hub shell or bearing? Rubbing disc brake? Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted February 23, 2010 Author Report Share Posted February 23, 2010 On 2/23/2010 at 11:22 PM, Alex Dark said: Over tightened hub bolts? snailcams binding on the hub shell or bearing? Rubbing disc brake? I'll check the bolts and snailcams, didn't think of that, and the rubbing disc is impossible since it's a maggie. lol Quote Link to comment Share on other sites More sharing options...
DannyBazz (: Posted February 23, 2010 Report Share Posted February 23, 2010 I had a similar problem, thought it was my profile. Turns out, my chainline was off.... Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 23, 2010 Report Share Posted February 23, 2010 On 2/23/2010 at 11:31 PM, DannyBazz (: said: I had a similar problem, thought it was my profile. Turns out, my chainline was off.... Or maybe chain rubbing on frame...freewheel spins freely? BB really stiff? Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted February 23, 2010 Author Report Share Posted February 23, 2010 I'm thinking it may be overtightened bolts. How do I correct this? When I undid in it coasted fine, but when I tightened ever so slightly it started doing the same thing. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 23, 2010 Report Share Posted February 23, 2010 On 2/23/2010 at 11:47 PM, J Trials 31 said: I'm thinking it may be overtightened bolts. How do I correct this? When I undid in it coasted fine, but when I tightened ever so slightly it started doing the same thing. Means either the bearings are munched, or when you tighten the bolts it forces something against the shell or the plastic dust cover of the bearing. I had the same problem when my snailcam rubbed against my hub shell. A very small washer sorted it Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted February 23, 2010 Author Report Share Posted February 23, 2010 On 2/23/2010 at 11:53 PM, Alex Dark said: Means either the bearings are munched, or when you tighten the bolts it forces something against the shell or the plastic dust cover of the bearing. I had the same problem when my snailcam rubbed against my hub shell. A very small washer sorted it Yeah, figured needed a new hub anyway, as it's been moving around a lot anyway as it's got bmx style bolts. I'll check for some fixes and start saving for a new hub. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 24, 2010 Report Share Posted February 24, 2010 On 2/23/2010 at 11:58 PM, J Trials 31 said: Yeah, figured needed a new hub anyway, as it's been moving around a lot anyway as it's got bmx style bolts. I'll check for some fixes and start saving for a new hub. Viz are good if you replace the axle with a nonthreaded one and file the bearing preloaders out slightly... Onza t-master are solid as fek with a new cro-mo axle rockman BUB seem damn good, and a reasonable weight. Quote Link to comment Share on other sites More sharing options...
J Trials 31 Posted February 24, 2010 Author Report Share Posted February 24, 2010 On 2/24/2010 at 12:01 AM, Alex Dark said: Viz are good if you replace the axle with a nonthreaded one and file the bearing preloaders out slightly... Onza t-master are solid as fek with a new cro-mo axle rockman BUB seem damn good, and a reasonable weight. Yeah, had a V!Z on my other bike and I did the same thing to it. Then it was great. Not sure what I'm going to go with, probably whatever I can get uber cheap used, but still quality. It won't be right away anyway as I don't have the cash for it. Quote Link to comment Share on other sites More sharing options...
