Cranks 170Mm Mod
Matt Vandart
unless your a weight weenie... longer cranks = more leverage, so your gear feels softer, which is good for static moves. short cranks = better acceleration, you benefit if your into taps and pedal ups. in theory it's really a personal preference thing.
You have faster acceleration with longer cranks, surely? You can spin them faster so with the same gear ratio it'll mean you'll gain speed more rapidly? Shorter cranks would give you a theoretically higher top end speed with the downside of slower acceleration, and vice versa for longer.
I found they benefited pretty much every move - made pedalups and taps feel easier if anything because you can take off harder and later because you can just slam the power down. Gaps and sidehops were a load easier too. It just wins all round.
