samster Posted February 20, 2010 Report Share Posted February 20, 2010 Every time i go riding my back (HS33) brake looses all its pressure/water that's in it. I've re-bled it, replaced all the hosing, cylinders and even the lever. but its still loosing the pressure and its very annoying. and also the cylinders aren't moving an inch. any ideas on what to do people? Quote Link to comment Share on other sites More sharing options...
WIGAN Posted February 20, 2010 Report Share Posted February 20, 2010 you sure your bleedin it right, no air in there ?? is it nice and solid when you start using it ? Quote Link to comment Share on other sites More sharing options...
samster Posted February 20, 2010 Author Report Share Posted February 20, 2010 you sure your bleedin it right, no air in there ?? is it nice and solid when you start using it ? i bleed it with a syringe and there's no air in there at all, and it does feel solid after i've bled it. but once i've bled it, after about 1 pull it starts to go down again, and i cant see where the water is coming out of either which is confusing Quote Link to comment Share on other sites More sharing options...
Captain Scarlet Posted February 20, 2010 Report Share Posted February 20, 2010 Have you checked the condition of your TPA? If the red TPA wheel has lost its thread (just over time and use), it cannot grip the lever rod, which affects how much your brake pulls in/bites. Just take out your lever blade, unscrew the TPA and if all is good give the threads a lube for good measure. I've had the same problem in the past, feels exactly like ripping your hosing, or putting your TPA all the way to minus. Quote Link to comment Share on other sites More sharing options...
samster Posted February 20, 2010 Author Report Share Posted February 20, 2010 Have you checked the condition of your TPA? If the red TPA wheel has lost its thread (just over time and use), it cannot grip the lever rod, which affects how much your brake pulls in/bites. Just take out your lever blade, unscrew the TPA and if all is good give the threads a lube for good measure. I've had the same problem in the past, feels exactly like ripping your hosing, or putting your TPA all the way to minus. yeah, my tpa doesn't work but it still has the thread on it though so i just keep it on the bottom of the screw all the time Quote Link to comment Share on other sites More sharing options...
multi tasking male Posted February 21, 2010 Report Share Posted February 21, 2010 i had this with my hope, it was leking and i didnt know where from so i just striped it all down, got new hoses and changed every seal in it, worked alot better than it did before and it stoped leaking. just rebuild it and change the seals. chris Quote Link to comment Share on other sites More sharing options...
matthew_coggan Posted February 21, 2010 Report Share Posted February 21, 2010 My suggestion just get a V brake on the back i just got so pissed of with hydrolic brakes braking. I changed to V and havent had a problem with it, and if they do break they are easier and cheaper to fix. just depends what money you have cos for a decent spec V brake will cost about 90 - 100 quid. Quote Link to comment Share on other sites More sharing options...
joea Posted February 22, 2010 Report Share Posted February 22, 2010 if i was you i would get a newl tpa and if that don't woke i would say you should get a new leaver ok i hopt that hlps you Quote Link to comment Share on other sites More sharing options...
chris4stars Posted February 22, 2010 Report Share Posted February 22, 2010 theres reason why so many stick with the hs33's!! if possible stick with it...when the problems fixed, it should be sorted for a good while if youre are doing water bleeds, try adding quite a bit of regular food colouring...pretty cheap, and hopefully should make it pretty clear where the leak is! when you know whats up, im sure theres a whole load of advice depending on what it is Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 23, 2010 Report Share Posted February 23, 2010 bleed brake, clamp pads into slaves with molegrips / vice/ hench hands. Slowly pull lever and watch for leaks. Will probably be the lever seal, or shroud nut connections. Quote Link to comment Share on other sites More sharing options...
a.rig123 Posted February 23, 2010 Report Share Posted February 23, 2010 try power bleeding it or try putting plummer tape round the end off the hose Quote Link to comment Share on other sites More sharing options...
zoo python luke Posted March 1, 2010 Report Share Posted March 1, 2010 Every time i go riding my back (HS33) brake looses all its pressure/water that's in it. I've re-bled it, replaced all the hosing, cylinders and even the lever. but its still loosing the pressure and its very annoying. and also the cylinders aren't moving an inch. any ideas on what to do people? so its a new brake... and its still not working? Quote Link to comment Share on other sites More sharing options...
moreton rider Posted March 1, 2010 Report Share Posted March 1, 2010 (edited) witch moodle is it . try replacing the piston spring and seals . ive got problems getting my hose onto the barbs any tips on this without using a vice and clamp blocs as i have neither Edited March 1, 2010 by moreton rider Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted March 1, 2010 Report Share Posted March 1, 2010 witch moodle is it . try replacing the piston spring and seals . ive got problems getting my hose onto the barbs any tips on this without using a vice and clamp blocs as i have neither *Which model The spring makes no difference to the sealing of the brake... Some flexible rubber to hold the hosing and mole grips can be used, although it is a hell of a job. Quote Link to comment Share on other sites More sharing options...
Balls Deep trials team Posted March 2, 2010 Report Share Posted March 2, 2010 I had the same problem with mine and it was the tpa so i just replaced the old tpa with a nut works just the same and didnt cost anything Quote Link to comment Share on other sites More sharing options...
Ben John-Hynes Posted March 2, 2010 Report Share Posted March 2, 2010 Did you replace crossover? Did you re-use the olives? If no, have you compressed the olives enough? Take the brake off the bike and let all the water out of it, do one of the bleed bolts back up. but on the other one attatch a syringe filled with air, push it through the submerged brake, bubbles should appear if there's a leak. Quote Link to comment Share on other sites More sharing options...
mckenzietrials Posted March 13, 2010 Report Share Posted March 13, 2010 Every time i go riding my back (HS33) brake looses all its pressure/water that's in it. I've re-bled it, replaced all the hosing, cylinders and even the lever. but its still loosing the pressure and its very annoying. and also the cylinders aren't moving an inch. any ideas on what to do people? Ive had this promblem my self it mainyy becuase of the pistons sicking and this causes pressure lose, you will need to buy a new piston you can get them of tartybikes or crc for very cheap but when you get make sure that it is in striaght or you could shatter the piston hope this helped Quote Link to comment Share on other sites More sharing options...
samster Posted March 13, 2010 Author Report Share Posted March 13, 2010 Thanks everyone it all helped and in the end it was my piston and tpa, there was no leaks/breaks anywhere else in the system so thanks people and my brake works awesome now Quote Link to comment Share on other sites More sharing options...
