Help Please >.<
sean1993
the only way that i can think of is drilling the bolt out.
to do that just get a drill, put a small drill bit, then drill it through, then use a bigger drill bit every time, until it comes out with the drill bit.(if you didn't know how to do that)
hope i helped :)
hope i helped :)
Nooo...
first try whacking an imperial size allen key in, thats slightly bigger than the original size. If not, then try bashing in a Torx bit.
One of they ^^ :rolleyes:
  On 2/20/2010 at 9:40 PM, multi tasking male said:
or if your able to do it without damaging your forks,get a haxsawe and cut into the bolt a little bit to make a groove and get it out with a skrewdriver so then its just like a skrew head.
chris
This, but use a screw driver, a skrew driver might not work so well. :shifty:
get a hacksaw and cut a grove in it and then you can put a flat head scrowdriver in it then you can get it out that way if that don't work drill the haed off the boult and tack it off and then cut a slit in it and then take it out like that
hope that helps
hope that helps
Why repeat what was said above, any luck sorting this out?
God knows.
Thought about cutting a slot in the bolt and using a screwdriver to turn it out?
:shifty:
You might find you can put a spanner onto the blade of the screw driver, which gives you more leverage.
