nickdonboy Posted February 20, 2010 Report Share Posted February 20, 2010 How much use can you get out of stone cutting disc? As in how many Grinds..? Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted February 20, 2010 Report Share Posted February 20, 2010 Don't grind your disk! You'll need a new disk and pads. It doesn't work. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 20, 2010 Report Share Posted February 20, 2010 How much use can you get out of stone cutting disc? As in how many Grinds..? Don't grind your disk! You'll need a new disk and pads. It doesn't work. He means angle-grinder discs... Well, a fair few, but as the diameter decreases, so does the area of the disc in contact with the rim when you grind. If its really wee you have to make more passes. Also depends if you sharpen it, what rim you use, and how harshly you grind. I'd say around 25 medium grinds maybe? My metal cutting last around 20 Quote Link to comment Share on other sites More sharing options...
nickdonboy Posted February 20, 2010 Author Report Share Posted February 20, 2010 Don't grind your disk! You'll need a new disk and pads. It doesn't work. lmao tool. He means angle-grinder discs... Well, a fair few, but as the diameter decreases, so does the area of the disc in contact with the rim when you grind. If its really wee you have to make more passes. Also depends if you sharpen it, what rim you use, and how harshly you grind. I'd say around 25 medium grinds maybe? My metal cutting last around 20 Cheers, but my stone cutting disc is no where near as good as it was after like 3-4 grinds? Proper nooooooooob to grinding, always ran smooth or disk. Quote Link to comment Share on other sites More sharing options...
