davey1991 Posted February 20, 2010 Report Share Posted February 20, 2010 I am currently using a Halo spin doctor hub on the back of my DJ bike. Its got a bit quiet and skippy recently so i want to service it. After taking the axle and bearings out and trying to give it a good old pull, there was no movement. As far as i'm aware once the lockring has been removed most freehub bodys simply pull off with a firm sharp tug. This is not the case. If anyone knows how I would much appreciate the help, preferably before my hub skips again and puts my face into the pavement. Thanks, Davey. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 20, 2010 Report Share Posted February 20, 2010 (edited) I am currently using a Halo spin doctor hub on the back of my DJ bike. Its got a bit quiet and skippy recently so i want to service it. After taking the axle and bearings out and trying to give it a good old pull, there was no movement. As far as i'm aware once the lockring has been removed most freehub bodys simply pull off with a firm sharp tug. This is not the case. If anyone knows how I would much appreciate the help, preferably before my hub skips again and puts my face into the pavement. Thanks, Davey. Hmm, I know deore hubs use a 10mm allen key to undo the freehub? Edit: Quick google Search reveals this...may be of some use More Information Halo Spin Doc. Freehub – Halo Spin Doctor Freehub Replacement Guide- · First step is to remove the push fit cones from the axle, just pull off and put to one side. · On a hard surface, firmly tap the axle in a straight down motion to push out one of the bearings from the hub shell. I normally tap from the disc side first to remove the more difficult freehub bearing first. · Turn hub over and repeat to extract bearing on other side of hub. · With the hub shell free of axle and bearings, place an 11mm (or Imperial equivalent – 7/16”) in a bench vice. Do the vice up tight, it’s about to do a big job for you… · Place the hub over the allen key, disc side down and lock in the freehub’s backnut. When in securely, turn wheel anti-clockwise. It WILL be tight, it WILL make a loud crack as the tension and threadlock is broken. · With the backnut removed, turn the hub over and place freehub side down over allen key in vice. Repeat anti-clockwise motion with wheel to unthread freehub from hub shell. Expect effort and loud noises as before. Be sure to remove small spacer from hub also, it fits directly behind the freehub in the shell. The most common fitting error on these hubs is incorrect replacement of this spacer. DO NOT attempt to replace it over the backnut thread on the other side of the freehub. · Have a good look inside the hub now you have the chance. Remove any grit, dirt or old grease and make sure everything looks good to go. · Refitting Freehub. Re-assemble hub in reverse order to dis-assembly, take care with freehub spacer as mentioned before. Also, take care when re-fitting bearings, it’s not too tough, just be sure they go in straight… Edited February 20, 2010 by Alex Dark Quote Link to comment Share on other sites More sharing options...
TROYston Posted February 20, 2010 Report Share Posted February 20, 2010 I use a hammer and block of wood, The axel will come out and so will 1 bearing , then use a big allen key to remove the other side. If it takes a gentle tug to remove it, id be worried . Quote Link to comment Share on other sites More sharing options...
davey1991 Posted February 20, 2010 Author Report Share Posted February 20, 2010 I use a hammer and block of wood, The axel will come out and so will 1 bearing , then use a big allen key to remove the other side. If it takes a gentle tug to remove it, id be worried . Not a gentle tug, a firm quite hard tug after you'd undone the retaining bolts, which i thought i had done, appears i had missed something. Snipington. Instant solution. Thank you Mr Dark. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 20, 2010 Report Share Posted February 20, 2010 Instant solution. Thank you Mr Dark. No problem Quote Link to comment Share on other sites More sharing options...
davey1991 Posted February 20, 2010 Author Report Share Posted February 20, 2010 Now to go find an 11mm allen key.... Garage search, COMMENCE!! Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 20, 2010 Report Share Posted February 20, 2010 Now to go find an 11mm allen key.... Garage search, COMMENCE!! If youre really syuck, I have one I could post Quote Link to comment Share on other sites More sharing options...
davey1991 Posted February 20, 2010 Author Report Share Posted February 20, 2010 If youre really syuck, I have one I could post I'll have a look in daylight tomorrow, then i may get back to you, thanks very very much. Quote Link to comment Share on other sites More sharing options...
