Peter Wright Posted February 20, 2010 Report Share Posted February 20, 2010 I duno why but mine never come with one, a grub screw for the leaver pivot pint. This pivot pin keeps moving out over time and use as it's pretty free, almost floating. A quick romage around and a DMR Replacment Pedal Grip Pin to the rescue. Stick a small dob of grease on there and wind it in. It doesnt sit flush but it works perfectly, threads are the same! So saves a few £ if you can or can not get one out of Adam and the boys as most will have DMR's, or your mate will! Quote Link to comment Share on other sites More sharing options...
TROYston Posted February 20, 2010 Report Share Posted February 20, 2010 The play, will eventually cause the thread to flatten out. I know no one with DMR pedals, as they are gay imo. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 20, 2010 Report Share Posted February 20, 2010 I duno why but mine never come with one, a grub screw for the leaver pivot pint. This pivot pin keeps moving out over time and use as it's pretty free, almost floating. A quick romage around and a DMR Replacment Pedal Grip Pin to the rescue. Stick a small dob of grease on there and wind it in. It doesnt sit flush but it works perfectly, threads are the same! So saves a few £ if you can or can not get one out of Adam and the boys as most will have DMR's, or your mate will! Yesh, nice contribution Pete....you can also use those for the reach adjusters on Avid levers, HS33 levers and the spring tension thingys for an Avid BB7. Quote Link to comment Share on other sites More sharing options...
davey1991 Posted February 20, 2010 Report Share Posted February 20, 2010 The play, will eventually cause the thread to flatten out. I know no one with DMR pedals, as they are gay imo. Ha ha, never used a set then? I would certainley never use anything other than DMR v pedals voluntarily. Quote Link to comment Share on other sites More sharing options...
TROYston Posted February 20, 2010 Report Share Posted February 20, 2010 Ha ha, never used a set then? I would certainley never use anything other than DMR v pedals voluntarily. Wellgo magnesium. OWNED, as the are the base to most good peals anyhoo. Quote Link to comment Share on other sites More sharing options...
Leistonbmx Posted February 20, 2010 Report Share Posted February 20, 2010 Not really. Personal preference. People like different things. Size/shape of body etc. OWNED. Quote Link to comment Share on other sites More sharing options...
Peter Wright Posted February 20, 2010 Author Report Share Posted February 20, 2010 There is a bit of a uniformed std between these grub type screws it seams as the elgos i have in store and fitted to bikes all seam to match the thread! Nothing wrong with DMR's. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 20, 2010 Report Share Posted February 20, 2010 There is a bit of a uniformed std between these grub type screws it seams as the elgos i have in store and fitted to bikes all seam to match the thread! Nothing wrong with DMR's. Yerp....M3 I thinks? Quote Link to comment Share on other sites More sharing options...
davey1991 Posted February 20, 2010 Report Share Posted February 20, 2010 Wellgo magnesium. OWNED, as the are the base to most good peals anyhoo. In no way have I been owned. I stated i prefer them, you saying wellgo's are better does not change my opinion, sorry lovey. Quote Link to comment Share on other sites More sharing options...
Peter Wright Posted February 20, 2010 Author Report Share Posted February 20, 2010 Yerp....M3 I thinks? Yella Yella Quote Link to comment Share on other sites More sharing options...
