Plastic Stem!
craigjames
At the end of the day, why not?
As long as they manufacture the stem to handle a certain amount of stress, similar to that of an alu stem then theres no difference.
Technology advances, better materials are made available.
Wonder if people thought the same thing when the first aluminium frame came out?
If it's done right there's no reason it wouldn't work. Lexan or UHMWPE (Or Ultra-high Molecular Weight anything really) would be two plastics I'd look at... Plastic BMX and MTB pedals have been around for ages too (And not just the crappy ones on cheap bikes). Keep in mind that BMX stems are usually a solid block of aluminium, so complete overkill for the loads involved (Given longer stems for MTB's are hollow tubes), so there's room to downgrade the material for that application.
Edited by psycholist
It appears they have used PC ( polycarbonate.... ) known for its strength and often referred to as bulletproof. This has been used by evil bikes ( e.13 chainguard anyone ?) and Truv to great success. Whether it's up to use under load I'm not sure.....I'd also be worried about the threads pulling out.
Polycarbonate Stats
6061 aluminium stats - As used on the tartybikes forged stem and many others. This is in the T6 variant, although probably the most suitable for this application.
You can see that PC is lighter than 6061....but the tensile yield strength ( I think the most relevant figure? ) is far lower at 40.7-73.5 MPa compared to the 255 of 6061. Theoretically if used well this material could be as strong as aluminium, but I reckons it would be more suited to something like a direct-mount DH style stem, where there would be far less leverage acting on it?
But plastic pedals have got a metal axle running through them, and they're still shit my first pair of gusset PCP pinheads snapped after 1 month.
You need to look at modern BMX stems if you think that's still the case...
That's because those pedals are shit, no matter who's name is put on them. The Animal Hamilton pedals are still the best plastic pedals out, apart from maybe the Fly Rubens.
And it wouldn't be half as susceptible to fatigue as aluminium is. Probably not, aluminium has been used for a hell of along time as a structural member in Aerospace and the automotive before it ever got used on a bicycle. Correct me if I'm wrong, but I haven't seen plastic very commonly used as an alternative material. Who knows though...
Shame it'll probably be about £100...
No reason it will be inordinately expensive.....the Truv PC bash's are pretty cheap, certainly not a huge amount more than their aluminium counterparts.
Yesh, forgot about the pedals.....top example. Like you say, it would be fine on something experiencing a relatively small moment. But that torque and thus shear force would be proportionally increased the longer the stem is.
A simple metal insert would solve the problem of thread pulling out, wouldn't take a lot to sort that surely? It has been and is being tested, surely a clip of it failing would have been put somewhere? Be interesting to see how long it holds up and how it fails if and when it does.
Pedals see SIGNIFICANTLY more stress than any stem. Using the plastic pedal as an example is also a horrible comparison.
The modern BMX stems are made from like 9-10 oz of aluminum. You can't tell me you have a lot of faith in something that's a double the weight of a beer can, but you have no faith in a high quality PVC stem simply because of it's material????
All things are likely to have some failure rate, but I don't think that stem, aside from some idiot tightening the shit out of it stripping the threads, it fail. Can't wait to see how this stem fares though. I'll reserve my judgement after i see some videos of it's use.
Edited by rupintart
Plastic pedal bodies, which is what people were refering to, will not see as much stress as a stem.
Yes, I can. In much the same way that I wouldn't necessarily want to have a frame that's tubing was made from 'high quality' paper instead of metal, there are different materials that are suitable for different applications. Just because it's 'high quality' doesn't mean that it's good for that purpose, and equally, simply making it using the same design as a metal stem wouldn't actually be using that material to the best of it's abilities, in the same way that making a direct copy of an aluminium frame out of, say, ti wouldn't make it a good frame.
Either way, not real, doesn't matter.
