Another Rockman Manus
Dan S
Finaly, i built up a bike and rode it a bit.
The bike is very similar to all other manuses except it's weight - 7900g.
Rides different to my kamel I had before....I guess I need a higher bar.
comments welcome.
Edited by Dan S
  Quote
My scales must be broken as mines 7.9 but got parts which are less weight etc hubs,bars,bb ?
list of the parts? I have Reset BB and a 520 g front wheel. Probably the wheel wins the difference.
  Quote
p.s change those forks before you die
3 rides old and I don't do much "up to front" moves - how much time do I have left?
what would you recommend? new rockman fork?
Edited by Dan S
I havent ever ran echo sl forks but what ive seen and heard they wont hold up for long.
The rockman forks look good but im still waiting for my pair from rockman.
My spec:
rockman manus
koxx forks
t-master stem
echo sl headset
pro series onza rim
echo sl hub
hope ti/carbon brakes f & r
Try-all carbon bars
ti reset bb
try-all superlight pedals
try-all cranks
pro series onza rim single walled.
echo rear sl hub
try-all front tryre
maxxis creepy crawler rear
both tyres with nobbles cut off
My spec:
rockman manus
koxx forks
t-master stem
echo sl headset
pro series onza rim
echo sl hub
Try-all carbon bars
ti reset bb
try-all cranks
echo rear sl hub
try-all front tryre
woahh nice spec, like the bike looks sweet!
Whats the t-master stem like?
My spec:
rockman manus - Rockman manus
koxx forks - Echo SL
t-master stem - Tryal 3D stem with alu bolt
echo sl headset - Echo Sl headset
pro series onza rim - Monty kamel Rim (250g or less)
echo sl hub - Tryall 'H' Hub
hope ti/carbon brakes f & r - Hope tryall F, hope mono with Tryall rotor and +20 adaptor. Alu bolts in both lever blades.
Try-all carbon bars - Monty 221 Ti bars
ti reset bb - Ti Reset bb
try-all superlight pedals - welgo Mg1 without much paint
try-all cranks - monty cranks
pro series onza rim single walled. - Tryal No war
echo rear sl hub - Monty 221 Ti hub
try-all front tryre - tryall front tyre
maxxis creepy crawler rear - Monty Eagle claw with nobbles off
I have to admit that I like the new Onza rear rim more than tryall.
And I (as well as you) forgot to add the tubes. maybe they make the difference? Mines are 120 each.
Edited by Dan S
  On 2/18/2010 at 11:13 AM, kristaps said:
Sweet..
+1..forks is light, but you should to change it ;)
crispyboy..
why you are using maxxis rear tyre? better than monty? :blink:
Maxxis tyres i think are the best out there.
Try-all seem abit hard
maxxis are hard but have alot of flex aswell
and monty are just to flexy you get tyre fold on everything
  On 2/18/2010 at 11:59 AM, Dan S said:
strange that all rockman users complain about little space between a crank and a frame. I have 10-15 mm left.
You must have a 170mm bb ?
  On 2/18/2010 at 11:49 AM, kristaps said:
They are very short and straight and beating my aurem, then I placed 2 washers..and all is ok ;)
where did you place the washers ?
being dumb haha
Really nice bike you got there mate, these are my favourite frames at the moment (except my sexy sky obviously)
Ryan's bike is sooooo light, couldnt believe it when i saw him the other day. Rides lush too.
The silver one they have bought out looks even more sex IMO
My spec:
rockman manus
koxx forks
t-master stem
echo sl headset
pro series onza rim
echo sl hub
Try-all carbon bars
ti reset bb
try-all cranks
echo rear sl hub
try-all front tryre
So much for a budget build :giggle:
Oh and to Dan s that is my dream buils minus the forks. :o
You luck basturd :P
