niconj Posted June 14, 2014 Report Share Posted June 14, 2014 Well, the Echo TR tensioner doesn't fit either. The pulley is too far inside and there's now way to adjust it. It's almost 1cm off to the left. Quote Link to comment Share on other sites More sharing options...
*gentlydoesit Posted June 14, 2014 Report Share Posted June 14, 2014 A pic of that!! A tentioner that doesn't fit their own hub?? Madness Quote Link to comment Share on other sites More sharing options...
niconj Posted June 14, 2014 Report Share Posted June 14, 2014 (edited) Well. I suppose that the Trialtech sprocket that ends on the right hand side of the threads isn't supposed to be mounted like this. In either case, having the sprocket in line with the tensioner would put the now perfect chain line off by around 1cm to the left; with an Echo sprocket it would still be 5mm. Oh and I'm such an IDIOT! I filed down the snail cam bolt to the level of the snail cam and now the 74kings fits as it is mounted between the hub spacer and the snail cam. Again. I'm an idiot! Should've done that earlier! edit: I will have to file down the spacer by one mm still as I have to widen the frame a tiny bit. Wouldn't bother with a steel frame but aluminum is different I guess. Edited June 14, 2014 by niconj Quote Link to comment Share on other sites More sharing options...
niconj Posted June 16, 2014 Report Share Posted June 16, 2014 (edited) Tested it yesterday. It worked except that it moved once and I had to tighten the bolt. FILE0013 von niconj auf Flickr FILE0014 von niconj auf Flickr Edited June 16, 2014 by niconj Quote Link to comment Share on other sites More sharing options...
