onza_rip95 Posted February 6, 2010 Report Share Posted February 6, 2010 Hey my name is Lewis. For some reason my TPA keeps breaking and stops moving. It is really annoying and I'm spending to much money on new levers and TPA's I was wondering if this is happening to anyone else as I am getting really fed up with it now. Any help would be much appreciated. Many Thanks Quote Link to comment Share on other sites More sharing options...
Borat Posted February 6, 2010 Report Share Posted February 6, 2010 Hey lewis, not spoke in a while mate. You don't need new levers all the time, just a tpa. Are you using one finger? And start afresh, but a tpa kit, then buy a metal tpa wheel off of tarty, so use the metal wheel instead of plastic and everything will be ok. Quote Link to comment Share on other sites More sharing options...
Leistonbmx Posted February 6, 2010 Report Share Posted February 6, 2010 Or just leave it. You don't need it to be working. Quote Link to comment Share on other sites More sharing options...
onza_rip95 Posted February 6, 2010 Author Report Share Posted February 6, 2010 Hey Jack thanks I'll try that and the other guy I do need the TPA I need to adjust it quite alot. Quote Link to comment Share on other sites More sharing options...
Borat Posted February 6, 2010 Report Share Posted February 6, 2010 http://tartybikes.co.uk/product.php?produc...p;category_id=5 http://tartybikes.co.uk/product.php?produc...p;category_id=5 Sorted. Quote Link to comment Share on other sites More sharing options...
Leistonbmx Posted February 6, 2010 Report Share Posted February 6, 2010 Why? You shouldn't need to use the TPA alot. Quote Link to comment Share on other sites More sharing options...
onza_rip95 Posted February 6, 2010 Author Report Share Posted February 6, 2010 Why? You shouldn't need to use the TPA alot. But its better to have a working tpa incase I need to to adjust the brakes Quote Link to comment Share on other sites More sharing options...
Luke_zoo Posted February 6, 2010 Report Share Posted February 6, 2010 But its better to have a working tpa incase I need to to adjust the brakes Or you can adjust the cylinders to your rim. Quote Link to comment Share on other sites More sharing options...
craigjames Posted February 6, 2010 Report Share Posted February 6, 2010 I make mid ride adjustments all the time, dependant on pad wear or how tired/cramped up my hands are. Having a TPA is really useful. Quote Link to comment Share on other sites More sharing options...
onza_rip95 Posted February 6, 2010 Author Report Share Posted February 6, 2010 I make mid ride adjustments all the time, dependant on pad wear or how tired/cramped up my hands are. Having a TPA is really useful. Agreed Quote Link to comment Share on other sites More sharing options...
Chambers Posted February 6, 2010 Report Share Posted February 6, 2010 I had the same problem as you but all was sorted when i bout the metal tpa wheel off tarty bikes hasn't failed on me yet definately recommend them Quote Link to comment Share on other sites More sharing options...
Revolver Posted February 6, 2010 Report Share Posted February 6, 2010 A good TPA is useful, but you can do without. To get a good TPA, either - - get an 04 lever and use a bolt instead of the plastic thing - get an 05 lever and get a metal TPA - get an echo TR lever, and make sure it doesn't leak before installing it - get an RB lever or an 04 body and Fresh Products lever Quote Link to comment Share on other sites More sharing options...
onza_rip95 Posted February 7, 2010 Author Report Share Posted February 7, 2010 I had the same problem as you but all was sorted when i bout the metal tpa wheel off tarty bikes hasn't failed on me yet definately recommend them If I was to buy one of thm would i have to buy the tpa kit aswell as that?? Quote Link to comment Share on other sites More sharing options...
Ali C Posted February 7, 2010 Report Share Posted February 7, 2010 using the TPA is fine in small doses, but it sounds like your winding it on too much and making the plastic dial come out of the threaded push rod. If you need to do more than a couple of turns, its best to move the cylinders closer to the rim. Quote Link to comment Share on other sites More sharing options...
