Question On Applying Break Boosters
Theo
Hi there, Got a Break Booster recently and im having trouble applying it. I have asked tarty bikes who are looking at photos of me putting it on atm to see where im going wrong, but Im after all the learning possibilities I can get :)
does it go on top of the break clamps in the middle or on the bottom? I have been trying on the top.
the problem seems to be the length of the bolts are too short or the spacers are too long, I cant get the bolt to bite on the thread of the frame probably because there isnt enough of the bolt poking out of the bottom clamp.
here some pics of the problem
http://img708.imageshack.us/img708/5139/67403872.jpg
http://img708.imageshack.us/img708/326/88980373.jpg
Thanks guys.
Thanks guys.
i would say mate dont use those long spacers , or get longer bolts. that brake booster does go on top and im pritty sure if its the echo then they should have given you some longer bolts
You are instaling the Booster incorectly.
Put the Brake and the clamps onto the frame, then the long spacers then the booster.
http://www.echobike.com/images/0809control...R-REARBRAKE.jpg
If you cant get the bolts to start then you will need longer bolts. Be careful when threading them, as its easy to strip the threads on the frame.
If you need any more direction dont hesitate to ask
thanks mate, I will wait and see what tarty bikes say i think, they might let me have some more spacers or bolts if im lucky ^_^
Don't tighten the bolts. It'll strip the threads in your frame. Don't bother. Get longer bolts.
yeah.. i found that out yesterday, only lost one though luckily, thanks for the warning anyway! :)
And yeah, they are all the stock ones that came with the bike so they should be standard
Thanks mate, I get what your saying, Il change that when I next put them on. going on what everyone says I think its time to get some new bolts :) might get some nice colourful ones
Edited by Theo
Thanks to everyone who helped, the final result was that I was putting the spacers above the booster instead of below. The bolts turned out to be fine, heres a pic of the finished thing :)
Thanks again, I have definitely learned alot by doing this!
Theo
