What Effect Does The Differnt Length Of Cranks Make?
aidanb93
As i have now bent the cheap crankset that is on my bike >_< . I now need a new set but as i have never had to buy them before i dont know what effect the different lengths make. If some one could help me out i would be very thankfull.
Also if you have any good cranksets in mind.
Many thanks aidan
It sort of an add on effect to your gearing choices. Such as longer cranks will give you better leverage but will give you lower ground clearance which on a bike which is already close to the ground could cause problems. so you have to find a balance between gearing and clearance.
