alistair14 Posted February 2, 2010 Report Share Posted February 2, 2010 Hi, right, my rear hub ( Monty 219 ) has kinda broke. I cross threaded one side of the spindle by accident and then the problems started, couldnt tighten wheel up right and the cones kept comming loose. we've tried rebuilding it with old parts but it still isn't working. Is there any way i could make it a sealed hub? any sealed kits? or do i need a new hub comments would be great Ali Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 2, 2010 Report Share Posted February 2, 2010 It's a fairly cheap hub to start off with...so I'd just replace it to be honest. Something like an Echo TR or if you can find it an Onza T-master hub would be ideal Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted February 2, 2010 Report Share Posted February 2, 2010 (edited) Why can't u replace the axle? Ur LBS should have one. use one out of a 135mm if you have to. Once you unscrew the cassete (sp?) off a supermarket hub and the like they are just the same as ur 'monty' hub so pretty much anything will work. Tip though. u HAVE to use the cones (more importantly the little washers that sit around them) otherwise ur hub is buggered. Edited February 2, 2010 by CC12345678910 Quote Link to comment Share on other sites More sharing options...
alistair14 Posted February 2, 2010 Author Report Share Posted February 2, 2010 Why can't u replace the axle? Ur LBS should have one. use one out of a 135mm if you have to. Once you unscrew the cassete (sp?) off a supermarket hub and the like they are just the same as ur 'monty' hub so pretty much anything will work. Tip though. u HAVE to use the cones (more importantly the little washers that sit around them) otherwise ur hub is buggered. we've tried different axles and cones, and it still dont work. and thats why im asking, can i replace it? Quote Link to comment Share on other sites More sharing options...
sstein Posted February 2, 2010 Report Share Posted February 2, 2010 we've tried different axles and cones, and it still dont work. and thats why im asking, can i replace it? Just get a new hub, it will be so much better and easier! Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 2, 2010 Report Share Posted February 2, 2010 Just get a new hub, it will be so much better and easier! Truth Quote Link to comment Share on other sites More sharing options...
aener Posted February 2, 2010 Report Share Posted February 2, 2010 Especially with TrialTech hubs being so cheap + good. Quote Link to comment Share on other sites More sharing options...
alistair14 Posted February 2, 2010 Author Report Share Posted February 2, 2010 Especially with TrialTech hubs being so cheap + good. should i stick with un-sealed hubs? or move to sealed Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 2, 2010 Report Share Posted February 2, 2010 should i stick with un-sealed hubs? or move to sealed 100% go sealed. Quote Link to comment Share on other sites More sharing options...
alistair14 Posted February 2, 2010 Author Report Share Posted February 2, 2010 100% go sealed. ahh okie. whats the best one? im kinda on a budget of around 30 - 40 quids Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted February 2, 2010 Report Share Posted February 2, 2010 ahh okie. whats the best one? im kinda on a budget of around 30 - 40 quids Erm....I quite like the Viz hubs, no idea on price though. I'm sure the TT sealed hub is fairly decent too. Quote Link to comment Share on other sites More sharing options...
