Echo Team 2005/2006
Mikey-uk
Heya, title and description pretty much sum it up.
I'm looking at getting a new frame once I start work and was going to go for somthing similar to my team frame, the Atomz AKT II XX kinda caught my eye 'cos of the chain tentioner (snail cams + brake set up have put me right off horizontal dropouts)
Could anyone else think of a different frame for me?
Keep the team. You won't find another frame like it.
Plus, it's not hard centering the wheel and setting up your brake. It's only because your chain is streched too much. ;)
I spoke to you about this, new chain (Y) Plus I have some notched cams on their way and a set of spokes for a rebuild later on down the line. to be honest though the non driveside snailcam doesnt really do much except pull the wheel out of alignment atm, hopefully the notched will sort this out.
I have a question to bump this with btw. Even with a 122mm bb my chainline is still retarded, is there any way to space out the kingcog? Like a single speed spacer?
