TobyThomasWilliams Posted January 31, 2010 Report Share Posted January 31, 2010 I recently put together my first bike not to long ago which brought up a few issues as the frames rear stays turned out to be pissed, which is probably causing all my problems. Anyroad as I started riding Ive found that the rear wheel will not stay straight and the cams just wont hold it! I looked into gusset kojaks but realised they wont run on the 20inch neon bow frame. im currently running try-all smooths as they offer the smallest minimum adjustment. I wonder if anyone else has had this problem, or can help me figure it out! Cheers, Toby. Quote Link to comment Share on other sites More sharing options...
ogre Posted January 31, 2010 Report Share Posted January 31, 2010 trialtech notched? echo tr ones are good apparently? tighten your bolts more? file smooth any burs on your frame where the hub usually sits. make the cams work with the bolts (so they push out with the rotational effect of you tightening the bolts. picture of your setup/ Quote Link to comment Share on other sites More sharing options...
TobyThomasWilliams Posted February 1, 2010 Author Report Share Posted February 1, 2010 trialtech notched? echo tr ones are good apparently? tighten your bolts more? file smooth any burs on your frame where the hub usually sits. make the cams work with the bolts (so they push out with the rotational effect of you tightening the bolts. picture of your setup/ Thanks alot man! I think im gonna try some notched and see how it goes, and smooth off the frame! Cheers Quote Link to comment Share on other sites More sharing options...
