Rhys Jones tonna trials Posted January 24, 2010 Report Share Posted January 24, 2010 Can some one shine some knowledge on how to set up a hope mono trial properly ive tried everything but it still rubs very agressivly HELLPPPPP!!! thanks for looking x Quote Link to comment Share on other sites More sharing options...
josh barker Posted January 25, 2010 Report Share Posted January 25, 2010 (edited) have you spaced the caliper out right with washers inbetween the forks and the caliper?? you might have siezed pistons?? how old is the brake mate? Is your rotor bent at all? Edited January 25, 2010 by josh barker Quote Link to comment Share on other sites More sharing options...
Alex@Flawless Bikes Posted January 25, 2010 Report Share Posted January 25, 2010 Put a screw driver inbetween the pads and force the pistons out. Sounds like it has beded in with the pistons out to far. Once you done the pull the leaver a few times and it should hopfully bed in better this time. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 26, 2010 Report Share Posted January 26, 2010 It'll be sticky pistons or a bent rotor I'd think Quote Link to comment Share on other sites More sharing options...
konstant Posted January 26, 2010 Report Share Posted January 26, 2010 Is the disk running centrally in the caliper? Is the rubbing constant or is the rotor warped? Quote Link to comment Share on other sites More sharing options...
