Freewheel On Cranks ?
brad1995
hi .. I have trialtech cranks and a tensile freewheel on the crank arm but when i screw it on , before it has chance to reach the back of the crank the teeth things that the bottom bracket tool goes into hit the crank therefore not allowing the frewheel to screw all the way on . I was just woundering if anyone elese has this problem with tenisle freewheels and if any certain spacers are required to go in the gap that is between the freewheel and crank or is it okay how it is . Thanks :D
