l33th3tr33 Posted January 20, 2010 Report Share Posted January 20, 2010 as the title says, my pedals are indeed, stuck. Wd40, brute force not working. And yes I'm turning them the right way. Please help, I don't like it when brute force doesn't work. Quote Link to comment Share on other sites More sharing options...
Skoze Posted January 20, 2010 Report Share Posted January 20, 2010 Get a bigger spanner and twat it with a hammer. Shock they asses off. Wait, you are turning them the right way, yes? Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 20, 2010 Report Share Posted January 20, 2010 You need to shock them loose, not 'brute force' them loose. And what is the 'right way' just so we know you're doing it right Quote Link to comment Share on other sites More sharing options...
l33th3tr33 Posted January 20, 2010 Author Report Share Posted January 20, 2010 (edited) as the title says, my pedals are indeed, stuck. Wd40, brute force not working. And yes I'm turning them the right way. Please help, I don't like it when brute force doesn't work. I'm using a big spanner, and levering with a big spanner. EDIT: I'm turning them clockwise Edited January 20, 2010 by l33th3tr33 Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 20, 2010 Report Share Posted January 20, 2010 Yeah, but just confirm which way you're actually turning them... I'll make it easy: 1. Right side: Regular. Left side: Opposite. 2. Right side: Opposite. Left side: Regular. 3. Right side: Regular. Left side: Regular. Simply option 1, 2, or 3. Quote Link to comment Share on other sites More sharing options...
l33th3tr33 Posted January 20, 2010 Author Report Share Posted January 20, 2010 left side clockwise, I'm not trying the other side unless this one will come off. (I'm stubborn) left side is off, same direction for drive side yes? (clockwise) Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 20, 2010 Report Share Posted January 20, 2010 If you're looking at your bike from the left side, then yeah, you need to turn it clockwise a.k.a. towards the rear of your bike, over the top of the crank arm. Right side is regular thread, so you turn that anti-clockwise. Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted January 20, 2010 Report Share Posted January 20, 2010 Easiest way to remember it: When fitting, pedal backwards. When removing, pedal forwards. Quote Link to comment Share on other sites More sharing options...
Tony Harrison Posted January 20, 2010 Report Share Posted January 20, 2010 If in doubt, take off the crank arm, put a spanner on the pedal, arrange it so that the pedal/spanner interface is raised above the ground, and then stamp - hard. Quote Link to comment Share on other sites More sharing options...
Mark W Posted January 20, 2010 Report Share Posted January 20, 2010 Easiest way to remember it: When fitting, pedal backwards. When removing, pedal forwards. Yep, either that or the thumbs up trick to remember which way to turn them. And Ian - that's what I was going to suggest before, but I couldn't think of how to word it. Pyramid system's pretty dece though. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted January 21, 2010 Report Share Posted January 21, 2010 left side is off, same direction for drive side yes? (clockwise) Nah, they are opposite threads... Check about 3:15mins onwards: http://tartybikes.co.uk/media.php?group=guides&id=4 Quote Link to comment Share on other sites More sharing options...
