Fiberglass
Luke_zoo
Your best bet is to make a mould, wax it, then glass into that. Are you using polyester resin or epoxy?
What kindof finish are you looking for? I've only ever really used glass on boats, but I use gelcoat for the final finish if I want something to look pretty.
Epoxy
unless you do that in two halves that will be a mission!
especially if you dont already have one something to mould around.
the thing is with most composites e.g fibreglass. is that the glassing is easy, its just the making of the mold that can be a nightmare!
making a mould like that will take a long time unless you have one already to mould around.
also im not sure what you got in this fibreglass kit, but it almost deffinately wont be what you need.
itll be alot easier to buy one mate, honestly
Cover your fairings in masking tape, fiberglass over, leave to set an then sand to win.
look how thin it is, the weight of the glass alone will distort it making a distorted mold, thus being useless as it wont fit.
also masking tape will leave a shitty finish, and moulding into a masking tape finished mould will never work.
there are ways to do it, but involve a few too many tools and other materials which will add to more then its worth
