Onza Limey
braderzz.p
i had the same problem my friend .
and i actually dont think there is a solution but i have changed my bottom brakcet to a 122.5mm
i have a 18-12 sprocket setup and same problem.
i think the solution could be either you buy a 118mm bb >> bottom bracket
and if that dosent sort it then you could change the rear sprocket to one of these. >> sprocket
and if that fails then flip the sprocket over but that could cause your chain to b out of line and snapy snap snap. >_<
hope that helps
chris
Edited by trialsrider.chris
