ryac Posted January 18, 2010 Report Share Posted January 18, 2010 hey all, I recently got a trials bike and both wheels use disc brakes. my rear wheel makes a honking sound when lightly pressing the brake. I heard it's normal for other types of brakes, but I thought I read somewhere that it's not normal for disc brakes. what do you think? is it normal or is something not set-up properly? thanks for your help! Quote Link to comment Share on other sites More sharing options...
matt tomlinson Posted January 18, 2010 Report Share Posted January 18, 2010 to my knowledge it is happening because there is some amount of rubbing going on. your pad is either set up to far in and hitting the rotor or your rotor is bent. if it is the latter you may be able to feel it performance wise. it may also be because you need new pads. to my knowledge thats the fix, but i am definitely not an expert. Quote Link to comment Share on other sites More sharing options...
Muel Posted January 18, 2010 Report Share Posted January 18, 2010 Does the brake work properly? I've found they make massive amounts of noise when the caliper seals have and there is oil on everything. But if it's just a kind of ringing, most of mine have done it, it's just down to whether the mount is face, how true the rotor is and how carefully the caliper has been shimmed out, my front one barely rubs at all, even with my home made +20 adapter on it. Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted January 18, 2010 Report Share Posted January 18, 2010 A proper honking noise is usually contaminated rotor / pads... Quote Link to comment Share on other sites More sharing options...
Mikey-uk Posted January 18, 2010 Report Share Posted January 18, 2010 (edited) Is It Normal For Disc Brakes To Make 'honking' Noises? Only if they're horny Edited January 18, 2010 by Mikey-uk Quote Link to comment Share on other sites More sharing options...
Laurence--Trials Posted January 18, 2010 Report Share Posted January 18, 2010 I personly have no expirence with disk brakes so this is just a guess: but if it only happens when the brake is lightly pressed then Surly it would make a little "honking" noise as you put it at least? Or should it just be a rubbing sound? Quote Link to comment Share on other sites More sharing options...
Revolver Posted January 18, 2010 Report Share Posted January 18, 2010 They can honk... sometimes they sing. Anyway, it's not usual behaviour for a disc brake. As muel said, it means something's on the disc. Quote Link to comment Share on other sites More sharing options...
ryac Posted January 20, 2010 Author Report Share Posted January 20, 2010 alright thanks. the brake seems to work fine, I'd suspect its some oil on the pads or rotor that is what's causing the noise. is it ok to clean the rotor with light soap & water and dry thoroughly? Quote Link to comment Share on other sites More sharing options...
davey1991 Posted January 20, 2010 Report Share Posted January 20, 2010 alright thanks. the brake seems to work fine, I'd suspect its some oil on the pads or rotor that is what's causing the noise. is it ok to clean the rotor with light soap & water and dry thoroughly? Nail varnish remover works far far better, just whatever you do make sure you wash everything off thoroughly. Quote Link to comment Share on other sites More sharing options...
mightyrod Posted January 20, 2010 Report Share Posted January 20, 2010 hi there,it sounds like you have got oil or somthing else on your pads or disc ,my advice is to take out pads an sand them down an give your disc a good clean to any god bike cleaner will do the trick Quote Link to comment Share on other sites More sharing options...
ryac Posted January 21, 2010 Author Report Share Posted January 21, 2010 hi there,it sounds like you have got oil or somthing else on your pads or disc ,my advice is to take out pads an sand them down an give your disc a good clean to any god bike cleaner will do the trick yeah, that's probably it. it's not that horrible of a sound and they are working fine so I'll try cleaning it. Nail varnish remover works far far better, just whatever you do make sure you wash everything off thoroughly. thanks for the info.. I'll try this if I'm gonna clean them. Quote Link to comment Share on other sites More sharing options...
l33th3tr33 Posted January 21, 2010 Report Share Posted January 21, 2010 Nail varnish remover works far far better, also known as acetone also, have you checked to see if there's a clown caught in the rotor? Quote Link to comment Share on other sites More sharing options...
